FS: 18" Breyton Race GTS and Eibach Pro Springs/Matched Springs/ARB Kit
Re: FS: 18" Breyton Race GTS and Eibach Pro Springs/Matched Springs/ARB Kit
just the wheels, $2000. thanks
i am not sure on that, never mounted it at all but 35mm should be flush or almost flush
Nice kit !
Any chance Suspension fits a Z4.
Mat;579361 said:
Nice kit !
Hi Mat,
yes it can be fitted on a E89 but not sure on E85?
Hi there, can the suspension set and wheels fit E46 sedan?
These are fit E90 fitment. I don't believe they fit the e46. Cheers!
Price revision
$3800 if you buy both the wheels and suspension kit
Wheels only - $1950
Suspension Set $2100
All items brand new in box.
Can anyone confirm 18"x7.5 is not suitable for e46? As i'm interested in this GTS but heard that it doesn't flush with the fender? True?
Based on the specs offset 35mm 18X7.5, it should be pretty flush but I am not sure if it will fit the E46 since I don't know much about the backspacing needed for E46. These wheels are purchased for the E90 so you might have to check with your wheels installer or you can check with some of the bros here. I know for sure the wheels will fit 3 , 5, and 7 series , need spacers for 5 and 7 series though. Cheers
I am curious why no one is interested in a spring and damper matched kit with anti roll bars when everything separately purchased will cost upwards of 3k.
topfuel;577497 said:
Will they be flushed nicely or e90? Or "in" abit
Just some sharing. My front 18x8 ET38 on 235 tires almost flush. Based on the specs of the breyton, it will be 8.35mm inner than mine assuming on stock 225 tires so up to you to visualize mentally. I think should be slightly sunked in but probably still acceptable. As for rear, confirm sunked in. My rear is 18x9 ET40 on 265 tires, which is 19mm more extension than this breyton specs asuming stock tires of 255, I still find it sunked in.
18x8 +38 with 235/40 = almost flush ?
i'm running 18x8.5 (0.5 inch wider) +35 (3mm more aggresive) with 225/40 = still not flush.
hmm, the 10mm tyres make a lot of difference ehh. must change to 235 next round.
bro
sms me at 81188746 for the rims
sorry bro, just saw your message, let me know if you are still interested. cheers
for those who are interested in putting these on the E85 Z4, I just saw one with the exact wheels today. If I am not wrong, Breyton made these in base sizes for 3 fitment, the 5 and 7 will slap on spacers to fit these. It might be the same for the Z4. Please double check with bros here but just a heads up, saw one today and it looked sweet.
Hi , are these rims still available ? Do they fit the 2010 3.18 ?
What's best price you can give for the rims ?
bro, just pmed you. wheels will fit 3 series E90/E92 from 2005 - current
Bro, im interested in ur rims.. will it fit my E92 coupe?
just did a check on breyton website
refer to this link Full Vehicle Fitment | Breyton Wheels
this fitment will fit on
1 series
3 series E90/E92
Z4 E85
Z4 E89
I also believe it will fit on 5 series with 10mm spacers.
okup3
