FS: UnderDrive Pulley !!!!!!!
Raptorsc
Have a real look at the pulley!!!
  • Increase stable horsepower and smooth torque across the entire RPM range.
  • Better fuel economy by 5 - 10%
  • 30% of OEM crank pulley weight to archieve great performance increase.
  • Designed and built with the same dimension of OEM pulley.
  • Construct with aluminium 7075-T6.
  • Hard anodized to prevent wear & tear.
  • Features harmonic balancer rubber to reduce minor vibration from crankshaft and minimize the noise.
  • Lab tested and well balanced to avoid any damages to the engine.
  • Item invented ,tested and manufactured in Australia.
  • Lifetime warranty
  • Plug & Play, hassle free installation.
  • Package contains:
    [*]1pcs lightweight crank pulley
    [*]1pcs lightweight alternator pulley
    [*]6pcs customize screw​
  • Available for model:-
    [*]E39
    [*]E46(4 potter/ 6potter)
    [*]E60
    [*]E90(4 potter/ 6 potter)
    [*]E92
    [*]E87
    [*]X3
    [*]X5
    [*]Z4
    [*]E66​
Interested may PM me. Item letting go at SGD 380.00. anyone ? :woowooo:
Re: FS: UnderDrive Pulley !!!!!!!
So this is the crank + underdrive pulley? what's the brand and how many pieces in the whole set? Interested and might be doing cash and carry.
Written there 1 pcs of crank pulley and 1 pcs of alternator pulley. So total of 2 pulleys ( 1 big 1 small ). Brand Swap Performance Australia.
Raptorsc;398405 said:
I m selling a brand new set of underdrive pulley. Item include of a Lighten Crank Pulley wif solid hard n lightest material wif powercoated on it and a lighten alternator pulley as well. Selling in a set. It fits E46, E39, E60 (2002-2008),E36,E90. Benefit of installing it as below :
1.) Increase in horse power
2.) Increase in torque
3.) Balancing damper include
4.) Better fuel economy by 5 - 10%
5.) 1 year/50,000km warranty
6.) Item invented ,tested and manufactured in Australia
Bro, I'm interested.. Can sms me @ 9060 4554? As I can't PM.. tks..
for which engine? I dont think the E60 or the E90 have any common engines with the E36
We do have pulley set for the N52/N53. Sorry for the E36 cause there is no production for M50 (E36) at the moment. thanks
Raptorsc;398450 said:
Written there 1 pcs of crank pulley and 1 pcs of alternator pulley. So total of 2 pulleys ( 1 big 1 small ). Brand Raptor Performance Australia.
eerr... I thought there are underdrive pulley, crank pulley and alternator pulley???
Bro ! sorry for tat mistake. Is not good to have undersize water & power steering pump pulley. It will make ur pump shorter lifespan.
tempting but any down side?
Bro,interested in your pulley set,can u sms me at 98512921 thks.
does these pulley fit/works on a E36 320?... checked UUC webbie, dun find 320 in the list...
hi
can it fix in e81 130i ?
i'm interested
all the best for your sales
Would you have the pulley for 2002 E39 M54 Engine. If yes pls sms me at 96861066. Thanks.
hi bro
you confirm my ride can fix.....
so pls contact me(sms)82666966
pg88comim
