FT86 = 86 (Hachiroku) / GT86 !!!
Re: FT86 = 86 (Hachiroku) / GT86 !!!
Photoshops
Let me start by putting the internet arguments to a rest. The new Toyota 86 is an epic little machine that will amaze you when you get behind the wheel and really go for it. It is also so simple and rewarding to drive on the limit and I’m certain it will be absolutely pounced upon by all sorts of people when it get’s released next Spring. Forget about it’s looks, power figure, weight and wheels for a minute and let’s just take a look at how good it is as a drivers car ( and for that matter a potential drift machine )…
Would you believe me if I told you the car was a disappointment at first? I’m still not sure if that sense of being “let-down” was either, a) because the car’s traction control system was cutting in and out ( making drifts virtually impossible to continue with ), b) the fact I only got less than 5 minutes with the car or c) the fact I actually had to get out of the thing at the end. I’d like to say it was a combination of all three but the anticipation of driving this car was really getting to me after all the teasing, all the leaks and all the rumors. 7Tune has covered this car non stop for years now. Like some sort of pent up sexual tension, I just needed release and the “86″ was the target of my desires.
I’m also definitely not the type of person to slowly feel my way into a car, especially on a racetrack where an internal switch goes off that puts me into “Circuit Mode”. I will go for it straight out of the box, explore where it’s limits, strengths and weaknesses are, confident in my abilities to control what’s within my grasp. I mean, what was all the motor racing I did throughout the last 20 years of my life worth if I can’t stretch the “muscles” every now and again? My plans for how I was going to approach the “86″ were the same as any other car and 200hp barely registers on the scare factor. A sideways Caterham at 180kph, an unruly Lamborghini Super Leggera on greasy roads or an aquaplaning R8 V10 registers on “The Radar” but those are different stories. The “Hero of the Day” award here goes to the magnificent “86″.
In hindsight, “Option A” was probably the real reason because it was, umm… my error. You see, getting into the car in my anticipation to get it on with the “86″, the first thing I looked for was the T/C button. I found it easily enough ( there are only a couple of these types of buttons to play with in the “86″ ), hit it once and watched the dash light up telling me the T/C was off, or so I thought. So I set off down the pit exit, chirped it into second and powered off into the track entry. Then I turned in and kicked the clutch expecting to get my swing on but I was rewarded with about 15 degrees of angle before the power was severed and the electronics tried to sort the chassis out, believing it was about to be crashed.
It was a frustrating 3 laps. Each time I threw the “86′s” light weight around to induce a slide, I’d bring the power in with the foot flat to the floor, the back would step out for a couple of moments and then the electronics, like cops raiding a frat party, would bust in and spoil it for everyone. So damn intrusive! This was a real problem now and I was punching at the T/C button like a madman, seconds ticking away from those precious 3 laps. Only 3 laps and I’d never even set foot on the Fuji Speedway short course before so there was also that to contend with.
But we continued, were called in and then, just like that, it was all over. I hopped out of the blue “86″, looked at it for a few seconds, bemused, and then started to explain in animated detail how the cars balance and flavor was to me as the driver but when the adrenaline eventually wore off, I felt something major, something really fundamental was missing from the experience and I knew I hadn’t got nearly enough out of the car as I could have. It nagged at my conscience. The T/C had completely spoiled the test! ( But we both know it was actually my stupidity. )
Cue Toyota. After relaying this in comment to a couple of the Marketing staff that did such a wonderful job to take care of everyone there, they actually found me a space right at the end of the day for one more run and I bolted over to Fuji Short again to make sure I got it right this time. There were no more journalists clamoring for a seat. No more spectators looking on and adding pressure. Nothing to prove. Just me and ‘ol Bluey with the track to ourselves. And sinking into the awesomely supportive factory semi buckets, I strapped in, and remembering what renowned motoring journalist Peter Lyon had told me earlier, held the T/C button down for a few seconds. T/C…disengaged!
Down the pitlane and at the end I kicked the clutch pedal again but this time the back stepped out wildly, caught with an armful of opposite lock. Bringing in the power, Bluey just rose in revs, sound and anger as it went right out sideways and up to the 7200rpm cutoff. This was much better! With the foot still buried heading into that first left, right, tightening uphill left turn, I wind it the other way and give the clutch a quick jab with a touch more anticipation than before and caught the back end stepping out so effortlessly and so naturally it took me completely by surprise.
The “86″ is not a snappy car in any way and it wasn’t floating around, “boatlike”, either. Rather, there was a rapid delivery of linear smoothness to the way it was coming on underneath me and the chassis sat low, felt tight, nimble and light as a feather; just reading the input and responding to what I was telling it to do. It is really very very simple to just get in the “86″, turn the key and go for it. Take my word for this because I believe I really found some of its limits even in that excruciatingly short amount of time. Driving this car on the limit couldn’t be easier. It will be so much bloody harder for you to wipe the grin from your face should you put your money where it needs to be!
I was utterly loving Bluey’s new character and on each successive lap, I pushed it harder and harder, getting lurid 20 or 30 meter slides out of it and with all the effortlessness in the world, transitioning as quickly as I dared through each corner I threw the car into. The chassis is brilliantly poised, neutrally balanced and with a weight distribution 53%-47% front to rear, you can clearly see ( and feel ) that much time had been spent finding just the right flavor for its handling.
The 2 liter boxer four sports direct injection from Toyota that appears to have made a distinct difference to the power delivery but there is that familiar boxer rumble coming from the front and it is slightly unnerving because the badges and engine sounds don’t match. Nevertheless, it makes a factory claimed 200ps (197hp) delivered @ 7200 and is backed up by 151 lb/ft and a 12.5:1 compression ratio. Hi-comp N/A engines are back in fashion, baby! Honestly, if you’re worried about the “power” of the car, don’t be; 200ps ( as a starting point ) is just enough for the car. Actually, I say it could do with about 20 to 30hp more but that’s easily achievable with some basic exhaust and engine mods from the catalog or from the raft of aftermarket modifications that are surely coming for the car during 2012 and 2013.
I know Subaru’s and know them quite well actually, having owned a 2006 STi Forester SG9 for many years and having driven some of the finest STi’s available in Japan and I am very pleased to say that the gearbox in the “86″ is a total gem to work with, having carried that sweet shifting, snickety, feel-good confidence that you’d expect from throwing through any good Subaru 6 speed manual. Toyota are even going to let you have the option to customize its ratios! The only let down really on that side of things was the clutch which, like the Forester ( and many other Subarus I’ve tested ) was way too light and lacked any real feel for when and how strongly it was going to bite. It needs more weight. Out back, the rear end of the car is spectacularly good and so easy to control with either the throttle, steering, brakes or combination of the three. Weights have been all but confirmed with the version I drove tipping the scales at 1240kg’s which is pretty decent. The ultra stripped out, bare bones version will be even less at 1180kg’s.
I just couldn’t get over how rapidly and fluidly it could be made to change direction, buttery smooth in its rubber smack-down to the tarmac, switching up on command like a prize fighter. It just got better and better with each corner. I’m not lying when I say this; there is an element to the way this car handles and delivers its power that was so reminiscent of the AE86 of old. Something special from the AE86 has been preserved, saved, carried over and then imparted with careful consideration into the new “86″ chassis. You’ll appreciate how responsive the car is to your input before anything else springs to mind.
Still, there were some people who got out of the “86″ and said, “…yeah, it’s orright…” or “…needs moar Powa…” but I don’t think they really got it at all and who can blame them with only 3 laps behind the wheel? Power is meaningless in a chassis made from rubbish and this one is made from pure driving ether, so surely we should be looking at, what I consider to be, the huge potential of the car as a complete and tunable “package” instead of as an overly hyped sum of its pieces in which a power figure is but one part? This car ( and with it the BRZ ) is going to be a game changer for the tuning industry in Japan which is, for lack of a better analogy, at the bottom of the 8th innings with bases loaded and 2 strike-outs on the board. Trust me when I tell you Japan’s tuning industry is in trouble and that it desperately needs a fresh injection of new “blood” to get specific markets moving again.
And how good is it to entertain the thought that Nissan will pull out the plans for the S16 they carelessly tossed in the dumpster a couple of years back? They really have to make that car now because they will well and truly been left behind by Toyota and Subaru if they don’t. Or perhaps not entirely. You see, according to very high ranking sources within Nissan and Nismo, both companies are carefully watching to see how successful the BRZ and 86 are going to be. In actual fact, I quote one as saying, “…we hope they sell well because that will validate the return of a car like the Silvia.” When I asked if Nissan were still developing the S16 in any way, the response was cryptic; “I’m sure if you ask them, they will say they have no comment on the matter.” Read into that what you will.
You have to keep in mind that this is the base model you are looking at and things are still under development on the car but it’s a pretty damn good place to start. Speaking of which, I have it on authority that TRD and TOM’S have been developing their own versions with 86′s for months now and may just be making a possible demo car or two for the AutoSalon in January. We’ll keep you posted on those developments as they come to hand. Sure, Toyota is still perfecting the recipe but you can guarantee this is what the final car will look like and I really like it. It has all the hallmarks of a winning combination ( perhaps the only downside being the restrictions to tuners apparently due to Toyotas direct injection system ) and stands to really recapture a lot of tuners out there in Driverland that have been yearning for a new chassis to pour development money into.
I’ll leave the final word to the paying customer as these individuals will vote with their feet and their wallets but before that let me tell you what Akio Toyoda san told me himself a couple of nights ago. I had the privilege of spending about 20 minutes with the President of Toyota at the Lexus Spindle party discussing the 86 and during that time we talked about the car on a number of levels. I gave him all my feedback as a driver and he mentioned that a lot of his own input had gone into the project and that he wanted to open a new chapter of Toyota to the world of performance car enthusiasts. He acknowledged the need for Toyota to change, has set his mind to the task and that the car you see in this post is only the beginning. I was thrilled to hear these things and throughly encouraged by his convictions and the strength of his resolution. I’m convinced the project will be a great success because the product is so damn good.
The AE86 of old was never about power and neither is the new 86; rather, it’s all about the finesse of the chassis and overall balance of the parts in play to offer such an enjoyable driving experience and I have to say that Toyota and Subaru have hit a bullseye that is sure to put a grin on the faces of anyone who gets behind the wheel.
The only question is… which one is it going to be for you? Toyota or Subaru? You decide…
Either way, everyone wins.
What Car review
Toyota GT 86 review - Car and Car-Buying News - What Car?
What is it? A two-door coupe co-developed by Toyota and Subaru which will go on sale in the UK next summer. The Subaru version is called BRZ.
Avoiding the modern trend for front-wheel drive coupes powered by turbocharged engines on the grounds that this ‘makes cars boring’, Toyota and Subaru have opted instead for a traditional front-engined, rear-wheel-drive solution, powered by a new 2.0-litre flat-four engine.
The GT 86 (pronounced eight six) develops 197bhp, which is enough to blast it to a top speed of 145mph, with the first 60mph completed in less than 6 seconds.
What’s it like to drive? For once ‘inspirational’ is not too strong a word. The GT 86 is not about how fast you go – its on-paper performance is merely average – but rather how you go fast.
Compared with the sometimes aurally dull turbocharged cars that pepper this class, the off-beat thrum of the flat-four engine provides a welcome change for the better.
However, the engine performs a supporting role to a chassis of a quality that’s rare at any price. It provides a level of driver interaction unknown in its class, courtesy of beautifully linear steering and a poise and balance that’ll get you back in the habit of driving not because you have to, but because you want to.
What’s it like inside? Cars will come to the UK in one spec only. A disappointing automatic gearbox (a six-speed manual comes as standard) will be the only option. Toyota has not yet finalised the specification, but says it will be fully loaded, with equipment including leather seats and satellite-navigation.
Sadly, no number of goodies will stop you spotting that the GT 86’s interior is sparse.
The low slung driving position is fundamentally sound, despite a steering wheel that's fractionally offset towards the middle of the car, but if you’re looking for an interior with the sense of occasion of an Audi TT, you’ve definitely come to the wrong place.
Storage space is minimal, while the back seats should be regarded as additional luggage space, rather than habitation fit for a human being.
Should I buy one? If you are in the market for a £25,000 coupe and love driving, get your name down now, for it seems likely that – at least in the early days – demand for the GT 86 will far outstrip supply.
If, however, you're more interested in style than substance, it’s probably not for you: the engine is quite noisy and the ride on British roads is likely to be uncompromising.
What is beyond doubt is that, when it arrives next summer, it will send a huge blast of fresh air through this class. The last time an affordable Japanese sports car felt this right, Mazda called it the MX-5.
Rivals:
Audi TT
VW Scirocco
What Car? says…
TRD
attachment.php
Hot Toyota GT 86 planned
Toyota is already hard at work evaluating a high performance version of the new Toyota GT 86 sporting coupe. Chief engineer Tetsuo Tada says that not only is a supercharged GT 86 envisaged, test cars have already been made and are being evaluated by Toyota Racing Developments, the Japanese giant’s in house tuning division.
Tada-san favours the supercharger approach because it is simpler to achieve than increasing engine size and doesn’t wreck throttle response as turbocharging might. Indeed Toyota says that turbocharging along with four-wheel drive and wide tyres are what make sports cars boring to drive.
Supercharging is also a key competence for TRD which has been offering this kind of forced induction as an aftermarket kit for Toyotas since 1998. He would not be drawn on what kind of power a supercharged GT 86 might develop but Toyota is known to consider the car’s chassis could easily handle an additional 50bhp to go with the 197bhp already generated by its Subaru 2-litre flat four motor, a view with which, having driven the car, we wholly concur. However he says the TRD is also looking at ways of modifying the suspension to cope with the extra power, raising the possibility of a still more substantial power hike.
TRD’s most popular supercharger conversion is applied to the American market Tacoma pick up, boosting its 4-litre V6 engine from 233bhp to 301bhp suggesting that a 280bhp GT 86 with, critically, a massive boost in the low down torque the car currently lacks would be easily achieved. Even in the unlikely event that all the modifications added 100kg to the weight of the car, its power to weight ratio would still at least equal that of the 326bhp Nissan 370Z, a car capable of hitting 62mph from rest in 5.3sec and recording a top speed of 155mph. The standard GT 86 needs around 6.8sec and does 143mph. It is not yet known whether, if approved, the supercharged GT 86 would be offered as an aftermarket pack or as a model in its own right.
Tada also confirmed that it was so important to his team that even the standard GT 86 drifted properly that special tests were incorporated into the car’s development programme specifically for this purpose, ‘the first time this has ever been done on any Toyota.’
EVO magazine 5 stars:
Driven: Toyota GT86 review and pictures | evo
What is it?
It seems like this car has been speculated over and reported on for years, but finally this Toyota coupe, and its Subaru sister, are here in final production form.
Known in Toyota guise as FT 86 ('Future Toyota') up to now, the car you'll be able to buy from June 2012, with prices starting around £25,000, is now called GT 86. Subaru's version, the BRZ, differs only in the shape of the front air intake, trim details and some suspension settings.
The GT 86 is that now-rare concoction, a simple, affordable, rear-drive coupé designed for pure driving amusement without being burdened by excessive technology – a sort of faster, sharper MX-5 with a coupe body. It uses Subaru-flavoured componentry, specifically a 1998cc flat-four engine and a platform derived from that of the just-launched new Impreza, but the idea of a front engine and rear-wheel drive is a welcome return to what used to work so well.
GT 86 development engineer Yoshi Sasaki says the GT 86 is for those who are bored with cars that are too powerful with their turbo engines, have too much grip with their huge tyres and four-wheel drive, cost too much and don't let the driver do enough. 'A fun car,' he says, 'is a car that you control.'
Technical highlights?
There's 197bhp at 7000rpm on offer here, but the fact that the 152lb ft torque peak arrives at 6600rpm tells you much about how this engine is going to feel. It has both indirect and direct injection, switching between them as needed, and a high 12.5 to one compression ratio. The six-speed gearbox is borrowed from the Toyota Altezza (Japanese-market Lexus IS), or you can have a six-speed, torque-converter auto from the Lexus IS-F.
Suspension is by struts at the front, double wishbones at the back, there's a Torsen LSD and – cue flash of techno-anxiety – the power steering is electric. Weight distribution is slightly rear-biased, total weight is 1190kg and the centre of gravity is said to be lower than a Cayman's.
What's it like to drive?
It restores your faith in cars. No excuses, no unsaid undercurrent that makes the best of the fact that cars are generally becoming more synthetic and less involving to drive. The GT 86 is a complete cracker.
Here's why. Our encounter took place on the Sodeguara racetrack outside Tokyo, full of bends and dips and lightly coated with rain. You need a car with sensitive controls for a track like that, and within half a lap you feel completely at ease in the GT 86 as rush right up to its limits. Via possibly the best electric steering system we've yet encountered, with much more subtle sensitivity than the new 911's system and a more mechnically-connected feel about the centre, you can exploit a balance perfectly tunable with the tiniest throttle inputs. Take a corner briskly and there's stabilising understeer; accelerate a bit and the understeer vanishes as the tail starts to dominate. From there to a drift is a land of opportunity with abundant signposting. Seldom is a car so up for a friendly game.
The brakes are similarly progressive, while the engine does its best work at high revs where it emits a beaty rasp somewhere between the sound of an Alfasud and a regular Subaru, but without the bass throb. Six closely stacked gear ratios make the best of the engine's peakiness. The auto alternative works well enough, if without quite the smappiness of a double-clutcher, but the manual is obviously the one to have.
Obviously we will have to wait to get one in the UK to deliver the definitive verdict on how it copes with real, bumpy roads - but on first impressions, it's brilliant.
How does it compare?
It makes a Scirocco seem synthetic, an RCZ anaesthetised, a 3-series Coupé over-complicated. This is a pure driving device like an Elise or an MX-5 with sharpened sinews. This is how a proper sporting coupé should be. Toyota intended it to embody elements of the 1960s 2000GT and the 1980s rear-drive Corolla Twin-Cam (AE86), and it does.
Anything else I need to know?
It's a two-plus-two, but Yoshi Sasaki says hopes the rear space will be used to carry trackday wheels – it's that sort of car. The interior is functional and well-finished, with a low driving position and no unnecessary gadgetry.
It's also the first front-engined, rear-drive, flat-four sports car since the 1950s Jowett Jupiter. Tell that to your mates at the pub. (On second thoughts, don't.)
The car looks better in the metal than in pictures. And if you drive one, you'll want to own one.
1180kg, RWD, 6secs...
Sounds like a lot of fun. Just like the BMW 130 kinda century sprint.
And in light weight design, it is even better.
Is this the answer to the mighty Civic Type R?
I think it is a potential!!
Well done Toyota and Subaru.
A product that will appeal well.
no indicative price yet
how much deposit must i put to reserve ?
is it stupid of me to order the auto version?
anybody knows if it has paddle shifters ?
- don't know
- maybe
- yes
[ame=http://www.youtube.com/watch?v=EKrh7wfwSvA]TOYOTA 86 Test Ride - YouTube[/ame]
auto version for me but dont know the differences between normal and high specs.
