GB : Affordable Coilovers for E90/E92!!!!!
Re: GB : Affordable Coilovers for E90/E92!!!!!
I have 1 set of ST Coilovers for E46 non-M arriving this Saturday!!!
Contact me ASAP!
'The Great White'
For those of you who are wondering what the hell this Suspension Technik Coilovers are all about...................
They are KWs, just that the steel used is of lower grade, that's all. No salt on our roads in SG and MY, so no worries about corrosion.......
For those who wanna know more about it, taxi ride with me during the next meet-up.
ST Coilovers Kits
Looking for that perfect balance between comfort and performance, styling, and handling without sacrificing ride quality and comfort? Your search is over, from the company that brought you the KW V1, V2, and V3, we have the perfect ST Coilover to suit your E90 / 92 needs. Coilovers are the BEST suspension solution for aftermarket applications, simply because all of the parts are designed to compliment and function perfectly with each other. As opposed to playing the guessing game of buying springs and shocks separate.
ST Variant 1
When it comes to choosing the perfect coilover, don't be cheap, do it right the first time; choose ST height adjustable Variant 1 Coilover Kits. Fully threaded shock bodies will enable you to customize your ride height for that aggressive stance that you've always wanted, without sacrificing safety, functionality, or driving performance. Each application is expertly engineered, designed, and test under road and of course track conditions in Europe to guarantee it meets and exceeds the Highest Quality Standards of the German TÜV.
ST Variant 1 Advantages
  • Matched damper and springs rates
  • Corrosion resistant zinc plated threaded strut housing
  • All around height adjustability
  • Integrated elastromeric bump stop
  • Self centering dust boot for insured durability
Galvanized Steel
Coming from the makers of KW suspension systems the only main difference between the ST Variant 1 and KW Variant 1 is the steel they use. While KW uses Stainless Steel for their shock housing, ST uses Galvanized Steel. However, this does not mean a drop in quality, durability, or appearance. Although coilovers that use galvanized steel are more prone to corrosion due to environmental influences (i.e. mixture of salt water); those in the lower states: California, Texas, Florida, Nevada, etc. don't have to worry about corrosion. Those in the mid to upper States that snow still don't have much to worry about as long as they do not drive in heavy snow conditions upon where salt is used on roads. to further ensure those with doubt about Galvanized Steel, ST has corrosion resistant zinc plating on all of their threaded strut housings for further protection.
About Coilovers
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Thanks for the review & support bro!!!!
ST coilovers In stock now;
1 set for all E46 non-M
1 set for all E90/E92 non-M
Contact me ASAP!
'The Great White'
Contact me ASAP!
'The Great White'
Re: Suspension Techniques Coilovers for E90/E92!!!!!
hi can it fit 130i?
how much?
cam pm me?
thanks
niuzai;411830 said:
hi can it fit 130i?
how much?
cam pm me?
thanks
PM you liao!
Reply soon yah!
'The Great White'
How much are the ST variant 1 coilovers and KW2 coilovers? I am contemplating a change from my stock. Ride is a E90 325i
Do the ST coilovers!
You won't regret!
Combine with H&R Swaybars = Steam!
SMS me at 96905511.
I have both in stock now!!
'The Great White'
Upz for you bro! U provide the best service man! kekekekeke
Kum Xia many bro!!!
'The Great White'
Same, enjoyed professional service from Wilman2776.
For our roads, I suspect the ST's would resist rusting as well as the metal parts of a typical car's undercarriage.
But being paranoid, I paid for the inox-line KW's.
Bro, can PM me the price and the price for the V2.
I am driving a E90.
Thanks in advance.
Lennie
Anybody interested??
These are made by KW & it's exactly the same as KW Variant 1 coilovers!! (Spring & Damping Rates)
100% Made in Germany.
Only with height adjustment, very comfortable as it's about 25~30% firmer than stock suspension.
Height Adjustment Range
Coupe
Front 0.8-2.0" Rear 0.6-1.8"
Sedan
Front 1.2-2.3" Rear 0.9-2.1"
These galvanized steel coilovers are made by KW & are a couple hundred bucks less than the equal KW Variant 1. With the manufacture lifetime warranty, there are no worries like with other companies that don't stand behind their product with a 1 year warranty or no warranty at all.
This is the Cheapest Quality Coilovers available now!!
Contact me ASAP!!
'The Great White'
1 Last set of the ST V1 Coilovers left for all E46 non-M!!
Contact me ASAP!!
'The Great White'
Contact me ASAP!!
'The Great White'
All ST V1 Coilovers are sold.
Thanks guys!!!
Please post reviews yah!!
Those who still wants pls let me know soon so that I can order them in!
'The Great White'
Hi Bro ,
Do you have any stock for E60 LCI model and also Can you PM the price for ST variant 1 coilovers
Thanks in Advance
Stanley
Astinal;422593 said:
Hi Bro ,
Thanks in Advance
Stanley
Sorry bro, ST don't make for E60.
Only choice you have is KW V2 or V3
'The Great White'
yeah. gor for KW coilover. they are great and no regret so far.
upz for bro wilman good service and TLC to my car during installation in pursuit of perfection :)
wilman, initially i asked for 2 fingers front and 1.5 fingers rear wheel gap. and you give me 1.5 fingers front and 1 finger rear. i got so accustomed to the look already. and now cannot accept any higher ... muahaha. i went to fong kim to change the tail pipe and when i parked at the slope, the front bumper "almost" touching the floor already !!!
'The Great White'
Hahahaha......Fong Kim place is abit bad for lowered cars, cos the road dips towards the shop & the stupid slope up to the shop......
Your height now looks fantastic & car handles alot better than stock right??
Keep this height for awhile loh.....unless you always have to go places with super steep slopes that might rub the chin of your front bumper, then lan lan have to raise the front to 2 finger gap.....
Enjoy bro & thanks for the compliment!!!
'The Great White'
Wilman,
Do you still have stock for E92 shocks? Pls PM me the prices k?
betvisacomse
