Group Purchase for Pivot Raizin Voltage Stabilizer
spc_76
PIVOT Raizin Voltage Stabilizer at $88 !
Group Purchase Price: $88 / pivot normal (With installation on site)
Group Purchase Price: $100/ pivot sound (with installation on site)
(Minimum 5 order)
Closing Date: 31/8/05
Pivot Normal Voltage Stabilizer $88
Please submit your Name and Contact number and Quantity required
1)
2)
3)
4)
5)
For more info, please take a view at:
http://www.the-pivot.co.jp/product/flame-se.html
Pivot Sound Voltage Stabilizer $100
1)
2)
3)
4)
5)
http://www.the-pivot.co.jp/sound/flame-vs.html
Or alternatively, if you want to buy directly, please contact me at 91125406. Thanks!!
Re: Group Purchase for Pivot Raizin Voltage Stabilizer
is the Pivot Normal Voltage Stabilizer @$88 incl the earth cable? what is the diff between the Pivot Normal and Pivot Sound Voltage Stabilizer?
I'm actually interested in grounding cables. Do the Pivot Raizin qualify as those?
(Minimum 5 order)
1)
2)
3)
4)
5)
1) Iceman - 97300330 1 pc.
2)
3)
4)
5)
The Pivot Normal Voltage Stabilizer @ $ 88 does not included the earth cable. You can add additional grounding cable at $ 35 including the grounding cable. The difference between the Pivot Normal and Pivot Sound Voltage Stabilizer is that the capacitance of the Pivot Sound have more and bigger capacitance than the Normal one. With the bigger capacitance, it can produce more voltage and give you better sound. If you are crazy about car audio, you should go for the Pivot Sound instead of the Normal one.
What do you mean by Pivot Raizin qualify for this? If i didn't answer your question, please correct me. If you want to install grounding cable onto your car, Pivot Raizin is compatible to install also. It is compatible to all vehicles with or without grounding cable. If you haven't install the grounding cable yet and want to install, we are giving offer for those who buy the Pivot Volt Stabilizer from us to have the grounding cable installed at the additional cost of $ 35 with the grounding cable. We will do the installation on site. More info, please contact me directly. Thanks for your interest.
Thank you. Will probable install with the grounding cables.
Jaskin,
For grounding cables, you should ask Piggy. He did mine. Don't know whether he still does them, though.
Hi...
May I know wat is the capacitance (Farad) for both the product?
Thanx
Make sure the 1 of the grounding cable goes from engine right to the batt behind yah....
hehehe
'Clan Master'
rex7_vtec said:
May I know what is this Voltage Stabilizer for?
Is the only difference between the 2 just the sound?
The difference between the 2 is because the sound pivot have bigger and more capacitance that will produce higher voltage than the normal volt stab. Thus it can supply better for the electrical devices in the car
Whisky_Tango said:
Hi...
Thanx
The capacitance for the pivot sound is 20,000 and the capacitance for the pivot is 15,000
Whisky_Tango said:
Hi...
Thanx
The capacitance for the pivot sound is 20,000 and the capacitance for the pivot normal is 15,000
hehehe
'Clan Master'
We will do one to two standalone common point in the front engine compartment. As you know if we want to link the cable back to the battery for the common point, the cable required will be extremely long and need to route under your undercarriage.
Thanx... so in Farad will be 0.02Farad and 0.015Farad
I always tot tat the bigger the Farad like 2 Farad, the longer the capacitance can last and more current can be stored and more readily to provide current when needed.
I DIY mine and its juz one capacitor with 0.08Farad. Yup you can tell the diff after install.
Cheers!
Cheers!
How much did you buy your capacitor and from where? Can share with the rest if have good lobang for them
I bought it at Sim Lim Tower. One 80,000 (0.08 farad) for $50 and if you can find bigger farad pls let me know.
Cheers!
Cheers!
Very happy for you to get the capacitance at so low price. By the way, is there any effect after installing??
bet69help
