Help needed.e90 320i gearbox overheated
Re: Help needed.e90 320i gearbox overheated
alvinado;1069938 said:
wow like that our german cars really not suited to local conditions.
Not really conti or asian... I drove Subaru legacy before E90... it over heat toooooooo... worst... traveling at 180km/h for ONLY half an hour to 45mins ATF warning came out !! SOME MORE with ATF cooler installed...
haha, if stuck in jam in the future must off engine and open window....Surely kana laugh by those Jap and Korean car owner...
But seriously I always drive with Windows down unless got passenger. Old habit. I think e90 not suitable for me, must get cabriolet next time.
Can consider next time wanna go msia to lut the car, can only go after sun down
Zincman;1069942 said:
Hi Bro Aaron, I replaced my gearbox solenoid about 40000km ago.I stuck at the jam, of cause using 1st gear only.Like tuttle crawling towards singapore Custom. After chop passport already , again jam in Singapore custom.Really nightmare
Ok, then maybe next time don't use gear one, just use auto mode.
Should not over heat again
I note that the pre-FL 320 has a small block-shape ATF radiator through which engine coolant flows. Has anyone supplemented/bypassed this with a traditional air-cooled Hayden-type ATF cooler fixed in front?
Is this problem unique to E90?
How come E46 nvr heard of this problem?
????? Is there?
The ZF gearbox is pretty advanced and overheating is not normal - this is what ZF says you should do if overheating happens ...... Quite surprise the autologic did not pick up any DTCs despite it showing up on the dash as a red gear .....
Bro red bean, u really power.so many info.my radiator has not changed before.
Does any1 replace the oil cooler before? I call 1 of the stockist.this oil cooler seem to be a seperate part.not inclusive when we replace radiator.or maybe some site sponsor ws can advice.
When it comes to radiators - maybe can check with R2D ?
I recommend all bros to replace the oil coolers for EO and ATF.
Mine had failed prematurely at 60k km and I had ATF inside my cooling system and coolant/water inside my transmission. It was one horrible experience, and I hope by sharing that no forummers here would ever have to go through what I went through.
Of course, it was made much better by R2D who responded to my emergency at 10pm in the night and worked through past midnight to rescue my car. This kind of bros (and lady), priceless man....
How much the part costs for both oil coolers?
Couple of hundreds. But that is besides the point because when they fail, the damage (gearbox/engine) is extensive, and can be expensive.
Was your engine also overheating before the coolers failed? Otherwise quite hard to determine when that part needs to be changed
Nope. The oil coolers could fail without warning. You may know it only after it fails, when the clutch starts to slip.
When the gearbox overheats, there is a couple of reasons.
1. You may have been gunning the car with very high loads (i.e. towing a load up a steep incline) But as we are singapoor people, very slim chance of this happening..
2. There is not enough ATF or its the wrong within the system to properly lubricate the system and this increases the heat load that the cooling system must deal with. ( this also quite rare)
3. The cooling system for the car is not up to scratch. i.e. There are blockages within the system that stops the cooling function from occurring. This can be in the form of air flow or coolant flow. The mechanic must check for these problems.....
Good luck
Good luck
Thanks alot Dr Rod...
