hi all. having prob with oil leaks n now even coolant water also hav oil in it n water became muddy brown.. anyone 1 encounter this before? n where to fix this prob. i was told if everything were to be fixed it will cost mi a bomb. anyone can help mi with this? thanks
but whatever it is, it will not cost you a few thousand bucks.
you will need to drive you car to the workshop and ask rod to help you troubleshoot. kinda hard to tell how extensive the work is going to be from here.
ya. i nvr change the water in coolant coz my mechanic says even change also no use. he open up coolant water is muddy brown n sticky. he says pipings crack n engine oil seeps into my coolant. wad i m afraid is fixing up the whole thing may cost mi few thousands.
the muddy brown colour of water doesn't necessarily mean there's engine oil in the coolant. it's like that because you haven't flushed your cooling system for a long time and it's filled with sediment due to oxidation.
in order to flush the cooling system, you have to either disconnect part of the piping, or stick a hose into the radiator, start the engine and literally flush out the gunk.
i advise you to seek a second opinion regarding your car.
crack in the piping? what piping? the only place where the cooling system and the engine lubrication system meet is at the engine itself - cooling system is a water jacket that wraps around the engine. so what piping?
hmm.. kk. thanks. i think i better go to R2D n ask roodney to check my car..i m a very new bmw driver here alot things i still need u guys to help mi out.. thanks alot..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
