Help Needed - K-Jetronic
cykhoo
New Member
Hi......
I have a 1978 BMW E21 323i. It is a very nice car. Unfortunately it can start but there is no 'slow' , so it cannot move.
I have been trying to find the K-Jetronic part for a while in JB but cannot find. Does anyone know where I can find the part?
Thank you.
Regards,
CYKhoo
Re: Help Needed - K-Jetronic
what part are u looking for exactly?..the ecu? i can try and help u find if u know what u're looking for..:)
Hi...
It's the fuel injection part call K-Jetronic fuel injector.
Thank you.
Regards,
CYKhoo
What is the Bosch part No? The injectors can be cleaned and flow tested...replace the filter basket, seal, pintle cap. There are workshops in KL specialised in fuel injectors servicing.
Cykhoo,
why not just change to jetronic the fuel distributor now is really hard to come by.
are there any bubbles in the pipes to the injector ? these have always cause a problem.
fuel distributor will not cause under power. unless the mechanism is sticky then you will also have a very high consumption high CO.
for the jetronic you will need to get the E30 inlet manifold and the wiring also the ecu and airflow sensor.
kernsqorg
