Re: Help! No brake Lights!!
the brake light is double filament bulb rite?? 1 filament lights up when lights on, the other filament when you step brake...
here is how i will solve it :
1) ask someone step brake, go to the rear light.. take test pen (those for testing 12v ) and test the wiring got electricity anot...
IF GOT:
2) Since got electricity.. high possibility is your bulb blow.. change your bulb...
3) still dun haf? check your connector.. sometimes connector lose.. or wiring drop out... take out check...
IF DON'T HAVE
2) check fuse... fuse blow, replace... if fuse nvr blow go to (3)
3) when i was playing around with the rear lights, i realised that alot of wires are peddled from the right hand side rear lights to the left... so if the main wire TO the right hand rear light is broken, both side also wun light up... go to the right side n test for electricity.. if don't have, high chance is the wire is broken mid-way along the route... trace the wire till you find the broken area....
Hope this helps... just my 2 cents opinion.
