arsenal62
Re: How to change low-beambulb by myself ?
JHLim,
You can DIY it but need to be careful and not to break the headlamp adjuster.
Imagine the headlamp is facing you and you are changing on you left side low beam bulb. Turn the bulb holder (elbow type brown color) like loosening screw (anti-clockwise) but less than 1/4 turn then slowly pull out, due to the o-ring on the bulb holder you need some strength. If possible hold the headlamp reflector tight before applying force to pull it out to prevent accidential break of the adjuster when you miss cue.
JHLim said:Checked the owners manual but cannot manage to open up the bulb clusters and replace a burnt bulb. Could someone advise how to open up the and pull out the bulb? Spent an hr figuring how to open up the holder but no success.
Does anyone have any clear instructions for E39. I am replacing to Philips Diamond Vision H7.
Shall I do it myself (and risk damaging the holder) or leave it to mechanic? Wonder if it is a simple DIY or not.
Thanks anyone for help.
JHLim,
