Slater;523449 said:wash it down with wheel cleaner 1st. any other very stubborn stains that cannot be removed use zippo lighter fluid. removes stains like a gem!
i dun like brush scrubs. will damage surface somewhat.XXX;523450 said:Thanks for the fast response Slater.
When I was still riding, I used a brush scrub to scrub my bike rims, is it advisable to use that on my car rims as well or sponges will do?
kenntona;523479 said:(1) Solution one - wash with Mama Lemon/McGuire Hotwheels/Sonax Wheel Cleaner, spray, sponge and hose off. After cleaning and drying, coat with a layer of Sonax Nano. It repels dust somewhat.
(2) Solution two - get BBK.
Slater;523490 said:u woul be suprise that even car wash shampoo will do if maintained regularly.
for remaining stubborn stains use zippo fluid. i no bluff u wan. else chop!C3P0;523593 said:Yes, I use car wash shampoo also. But not very clean, but nevermind la. I cheapo one. Somemore make my maid wash rims for me. :chinese:
Not true donald. You see, I smaller size, shorter, thinner, flatter, than Ken. But doesn't mean I am cleaner mah, tio bo? :nehnehhh:donaldho;523586 said:BBK no dust meh? bigger brake, bigger pad, bigger rotor= more dust
XXX;523447 said:Hi everyone,
like to know any tips to clean stubborn dirt from rims I think caused by brake dust?
Thanks a lot
careffour or giantXXX;524672 said:Hi, where can I buy Sonax rim cleaner?
rosschang;524688 said:just use soap n foam... it's as easy as 123...
or any rim cleaner liquid will do... be aware of excessive use of rim cleaning liquid as they May(or may not) thin the shiny layer of the rim..
Expensive, but worth the $$$.XXX said:Is Sonax Nano worth investing?
