yendor
Friends...
Standalone ECUs do not work very well with auto transmissions as the gear changes will be done under full power. Transmissions these days have computers ( EGS in BMs ) that talks to the engine ECU to signal them to retard ignition or cut fuel when the transmission is about to change gears. The communication between the EGS and ECU is not merely a voltage signal level between them but rather a complex digital data stream. It is for this reason that piggy back systems flourish and are so adaptable.
In the topic of turbos and superchargers, a turbo is an exhaust mod that carries a fine of $500. :| A supercharger is an engine mod that goes for $2000. A change in capacity is a criminal offence as it invilves cheating the government....
If low end torque is what you are after, can consider changing your final drive to a slightly higher ratio. this has to be balalnced with the cruising requirements.
