how to lower car
dukes4
hi all
my ride is sedan E46.
how can i lower my car as i think stock shock is gone already. dont think i want to buy coilovers as might just keep ride for another 2 yrs only. any recommendatiions? like springs and shock set , how much will it cost?
thanks
Re: how to lower car
2 ways.
i) Change ur springs to lowering springs. Recommendations are Eibach/HnR springs.
ii) Change your struts to better ones like KONI FSDs or Blistein shocks and then change ur springs to any of the above mentioned...
Option 1 is cheaper. But not very healthy for your stock struts.
Option 2 costlier but its a very comfy setup and it will nvr go wrong...
Herman;365651 said:
2 ways.
thanks herman,
for option 2 do you how much it cost and also where can i can it done? i asked BVO before but was told to change spring and struts cheaper than coilover but cant lower the car.
it still lowers the car, but not as much as the coilovers.
get a grinder and cut 2 coils off your standard springs. cheap and good
Option 2 will cost approx. $1800 at J4C.
I imported mine frm the US and installed at FK...
And it definatley LOWERS the car.
Before i changed my shock absorber mountings, front and rear finger gap was 0. Finger cant squeeze in.
After changing the above, front and rear is almost 1/2 finger gap. When its too low, problems arise. So had to change shock absorber mountings.
for coilovers for E46, will it be possible to use it on the E90 in the future?
