How to tow a e90 320i
pegaki
I heard that e90 320i cannot be towed from the front
not sure what is the reason
What is the correct way to tow a e90? From the back? or put the wheels on a caddy?
Which tow service do you recommend and what are the charges?
Re: How to tow a e90 320i
Best way is to on bedded truck. Else tow from the rears is eBrake is engaged or put all wheels on caddy lifter
AAA service
Give them a call bro on $
casper77;1127263 said:
Bro, join AA.Towing foc...
FOC is for regular towing, once you want to put on truck bed or caddy then there's an additional charge. Can't remember, think it's between $60-$100 extra. Best to call them for quote
cheapest on caddy is $110, range from $110 to $130
regular tow without caddy (ie hook up from the back) is $40 cheapest, range $40 to $60
what is the danger of hooking it from the back and rolling on front wheels?
what happen to your E90? or you doing some survey?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
nothing happen
just doing a market research
pegaki;1127275 said:
nothing happen
research is good ; prevention is better than cure or last min...
fb88bet50
