Moonbus168
Hi guys,
This is my first post here so hello everyone!
I just got a 2nd hand BMW and had done a inspection today at PML and the results is quite shocking.... can u help let me know which ones of these are essential fix as there is only about 1 year left on the car and i do not want to spend more than I need to.
visual inspection found:
1) Engine oil pan gasket leaking ($600)
2) front and rear crankshaft oil seal leak ($1150)
3) coolant heater return hose leak.
4) Coolant heater supply hose to auxiliary water pump ($150)
5) Cylinder head coolant end plate cover ($180)
6) Connection pipe at cylinder head coolant leak ($270)
7) Radiator notice there coolant stain. ($1000)
we also found fault register for the electronic. those fault are:
1) fault for axuiliary water pump weak - ($470)
2) fault for front ride height sensor. Setpoint out of spec. need to change the control unit and the height sensor as preventive. ($1200). this will affect your headlight beam throw.
Other than that:
1) All absorber leaking. ($3500) includes wheel alignment
Other than that:
