Is there a standard Idling speed F10?
  • 700
    Votes: 0 0.0%
  • 800
    Votes: 0 0.0%
  • 900
    Votes: 0 0.0%
  • Total voters
    0
Re: Is there a standard Idling speed F10?
Red_Bean_Bun;1079651 said:
And idling got 2 profile - with aircon and no aircon.
No aircon will be lower than with aircon.
Fyi only.
Sometime idle set higher is to mask problems ....... e.g. for second hand car sale.
You are spot-on.
Actually for BMW, the average RPM is normal around 800-900 rpm. Cannot set too low as when the AC kick in, the engine might vibrates a bit. If above 1000 will be a waste of petrol and needs a tune up.
Wahlau, idle will fluctuate when hot/cold or AC on/off... where were you seeing 900rpm? car is digitally controlled... and yes they can +/- the idle using a computer tool... but unless you are having issues (e.g. too low causing vibration) you shouldn't worry.
million dollar question... what's your FC?
Meek;1079663 said:
Hachi28, your car no eco-pro??
Yes I have eco-pro, but previously it still idle at 900rpm.
Thank you for your reply. I see 900 rpm when idling speed after 10 minutes of driving with AC turn on @ neutral.
Neutral?
Normal.
What happens when in D?
Love the new display for speedometer, etc. BTW, 16.3km/l? Hahaha, most of us be happy with 50% of that!
The comment on the FC is superb.
When I took the car from PML, I put the trip computer on the split screen to monitor the FC. One month later, my screen is always on sports display ......... ;)
pg88comim
