Keep having to top up engine oil
Hi guys. I just bought an 8 year old e90 a month ago. I did full servicing right after with liqui moly engine oil and some additives as recommended by the mechanic so that the engine oil will last longer.
However 2 days ago the low engine oil indicator turned up and i topped up 500ml of mobil1 engine oil and it went away. Unfortunately the light came up again today. (Mileage around 120km for 2 days).
Anybody experienced this before? Thanks!
Re: Keep having to top up engine oil
Might be leaks in your engine.
Since 1 year more, pls do minor repair n use thicker oil with 50 grades would help abit depending how serious the leaks are.
U might like to pop up engine hood to search for leaks.
Ive checked and i cant find any visible leakages. But i do notice there's a lot of white smoke at times.
2 days 120km for 500ml of EO is alot.
based on white smoke you saw, major repairs are needed.
your piston rings and valve i think wore out already. go back to your dealer ask them sort it out.
Too bad cannot use cobb on your car ....
CONFIRM LEAKING...please send to reputable BMW workshop to check.
