Ever since installing V-Kool, my key is getting less and less sensitive. However I have another car and no such problem exists. I recalled reading somewhere that the BMW key is self-charging. Am I wrong? Is there a battery inside that need changing?
ya, maybe vkool's metalic base cut down the frequency a bit. i have the same problem too but got used to it. just press only when u are 3m from car lor.
heard that with certain solar films when applied to car does affect the signal range of the key. happened after changing solar films on my car as well. so just have to go closer then use the key.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
