LED light
Re: LED light
Yup, changed the light and had no problems.
I dropped by one of those light and ICE accessories shops opp. PML Alexandra one day when I was trying to kill some time. Wanted to do this long ago, but didn’t get around to it till recently. Inspired by ‘j8833t’ lah…
Was initially looking for white bulbs (actually looks blue) to replace the existing tungsten bulbs for the rear number plate lights. They did not have any of the white bulbs of the correct wattage and offered the LED ones instead.
Asked the auntie there to let me try it on without any cost (just in case it didn’t work).
REMOVAL – Open the boot. It’s easier this way. On top of the license plates are 2 lamps that house the bulbs. You need the screwdriver to pry the plastic transparent covers out. It’s quite easy. Just insert the screwdriver into the slot on the right side of the transparent cover and gently lever it out.
The bulb is under the cover, wedged in between 2 metal pieces on the sides. These are the contacts. Using the screwdriver again, GENTLY pry the bulb out. I would like to emphasise GENTLY – the bulb may be hot if you have just switched on your lights, and you don’t want to break it.
INSTALLATION – Check that your new bulbs are the correct wattage – 5W. Anything more and there’s a chance that the plastic housing will melt – too much heat generated. You can either use the white (blue coloured) bulbs which are around S$1 each, or the LED-type bulbs (I bought them for S$17 each). Just fit them and voila! You’re done. Make sure to clip the transparent covers back snugly, mine have been popping out now and then.
Switch on your lights at night and stand back to admire the new cool look.
Have fun!
Re: LED light
Thanks to jinooi, I've also got my licence plate lights changed to white LED. Damn swee!
Herman, you still on yellow lights? Time to change liao! :nehnehhh:
Re: LED light
Herman, you still on yellow lights? Time to change liao!:nehnehhh:
Able to share the brand of the bulbs that you bought?
Thanks!!
Re: LED light
Thanks!!
No prob bro. Jinooi actually got it for me, but I'll check the packaging and get back to you tomorrow :)
Re: LED light
C3PO said:
No prob bro. Jinooi actually got it for me, but I'll check the packaging and get back to you tomorrow:)
Thanks Bro! I went down to Autobacs on Saturday.
Look at some of the H-Series PIAA LED Bulbs. But one of the Technician there says that PIAA LED bulbs are only 1W when what the stock is 5W. Hence will cause a error msg at the OBC. Have been looking for a 5W LED.
Thanks for sharing these info jinooi and C3PO.
Re: LED light
j8833t;314480 said:
Yeah..no indications of any sort or whatever on dashboard. Another bro, JINOOI also had it changed recently at another autoshop along Alexander Rd..no problems too.
BTW, our rides are E46..wouldn't know about how sensitive the electronics stuff are on your model.
Ya maybe you are right different in model cause different effect. Mine is E60 so I m quite sure many sensitive electronics issue. Well I guess got to contuine my hunting :( :(
Re: LED light
hey nicky
what you can do is go and fit on the bulb and see whether anything shows up on the instrument panel. if the wattage is the same, i don't think it will show up - voltage has to be 12V. the car will only detect if the resistance is less - thinks that the bulb has blown.
but don't take my word for it (returned all my physics to my teachers long time ago). Go and try it out at a smaller shop. that's what i did. told the boss that i will not buy if it doesn't work for me. she also wanted to know just in case some otehr bimmer driver comes along.
so far it's been a week and nothing has showed up on the instrument panel.
can somebody give some info - the sensors for blown bulbs are only for headlights and taillights only? license plate lights and interior lights do not have sensors attached?
just make sure you have the correct wattage, max 5W. or else it will melt your housing and lenses.
Re: LED light
Has any of you guys tried fitting LED bulbs on the bottom 2 reflectors on the E60? I've seen like 1or 2 of it being done up n if looks pretty nice. Anyone who has done it could kindly share on the procedures and how to do it?
Thanks a million!
Re: LED light
Thanks!!
Hi bro,
The brand is ALPHA-01.
Alpha LED. Size is 10 x 36.
12V 1W.
Re: LED light
C3PO said:
Hi bro,
12V 1W.
Hey bro, urs is the 1W one izzit? I don't think it can work on the E60. The pple at Autobacs said that the OBC will come out with errors.
Either
1) It won't on.
2) It will show that the Licence Plate lights are spoiled.
Do you know whether they have any 5W ones? Coz AutoBacs doesn't have any brand with the 5W LEDs.
Re: LED light
Either
1) It won't on.
Heh heh bro, your car too high tech le.
Why don't you try to go down to the shop and try it out?
Re: LED light
Hi, I'm a merc owner. I have installed the LED-lights I bought from my friend. Previously I had 6 LEDs for the license plates. Now I upgraded to 18 LEDs. This is the pic of 6 LEDs.
watermark
A resistor or 2 is needed to bluff the computer in the car. I don't know the value but the resistor comes together with the light bulbs.
The LEDs will not heat up but the resistor will. So as long as it isn't touching anything it'll be alright. The wires that came with it is strong enough to allow the resistor to suspend in the air.
For merc, no re-wiring needs to be done because as long as the wires can be connected then will be alright. But for BMW I'm not so sure. Maybe after I change to E93 then I'll see. :)
Re: LED light
Calling jinooi, calling jinooi, got 5W LEDs?
LoL.. no la bro.. So many E60s ard.. Mine not special at all la...
Actually how does our license plate bulbs look like anyway? :screwedu:
The 1st pic or the 2nd pic?
Re: LED light
The 2nd picture!
Re: LED light
Wa robot.
So fast back in office?
So how was LUNCH BUFFET AT MARINA MANDARIN ?
Re: LED light
Herman;315476 said:
Wa robot.
Ya, must race back to surf forum mah :)
Lunch was good, but super long queue. In the end, didn't even have dessert.
Next meetup jinooi and me show you our white LED lights :nehnehhh:
Re: LED light
watermark
Hi bro where to get this bulb and also how much it is?
thnks
Re: LED light
I got it from my friend. if you want I'll have to check the price for you. But need the length of the bulb. and the number of LEDs u want. If i'm not wrong there is 6 LEDs and 18 LEDs. The difference.
Re: LED light
I dont want white lights la.
My interior is already light coloured...
If put white again machiam hospital.
Jeff said my lao pok orange lights suit my interior better.
m88bz1
