Looking for Spacers
joe49sg
Hi everyone ,
i'm looking for a pair of 20mm spacer for E90 . centre bore 72.56mm and comes
with long studs.
if anyone has a Used set siting around please Pm me with your offer .
Re: Looking for Spacers
20mm? Gosh........
AFAIK the 20 mm ones doesn't come with long studs. The pair i used before came with another set of normal length lugs. You screw the spacer onto your wheel hub. Then you mount your wheels using the original lugs onto the spacer.
Yes , i've read some old post and yes that is 1 option , there is those that uses long bolt direct.
Anyway both option also can .
So anyone has a pair for sale ?:juggle:
make me an offer. i might want to see mine. 20mm eibach spacer currently on e39 and also long nuts
joe49sg;556306 said:
Hi everyone ,
with long studs.
go order from a reputable tyre shop. costs less than 300 for a good brand like eibach. no point getting a resale one for something that impt. we often disregard labour cost when buying 2nd hand, after adding up, may not be worth it. cheers.
789wintoday
