Lowering car with H&R springs - comfort concern
Re: Lowering car with H&R springs - comfort concern
Hi guys, after so long, I finally find the time to do it.
So now my ride is installed with the HNR Springs (Sports) and it's much lower.
The ride is very nice, less roll. It's *slightly* harder than stock. I think it's better as there's more control and less roll. It is also less bouncy.
To keep the longetivity of the stock shocks, I'll be driving slow during clearing curbs. With stock I can just run over it. Lol
HOWEVER, to be a little anal, I find the back is lower than the front wheels. Can I adjust this? (even without my bike mounted at the back) any advice?
Here's a pic :)
Sharm
Here's a pic :)
Sharm
Looking good.......
* only coilover can adjust to the height you want..............lowering spring standard height
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Looks nice bro. But too bad cant adjust, mine also rear lower than the front.
Here's a pic :)
Sharm
My rear right lower than my rear left. Anyone got this issue?
Thanks guys. My last ride was an integra. When this happened, my workshop actually CUT a portion of the springs to lower and balance them up. Even tho nothing happened, I don't think it's a good idea for us to do that on bimmers. Be safe. Better get proper shocks and coilovers to attain car height of your 'dreams'. Lol
If lower springs combined with stock suspension, cannot make it after 2 years. My suspension is too soft now i think its due to the lower spring. Every time go pass hump, sure brush against the wheel arc.
After lowering ride, need to adjust camber and toe?
true go for coil over.. dun use h&r ya,, very boucy...
Coilover Rocks.........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Just wondering. Now that I'm on HNR (happy with it so far) - in the future if I'd like to change to coilovers, do I need the original springs/shocks then? (pardon noobie question)
Coilover got everything.......
* you can keep the present set.........
cheeeeeeeeeeeeeeeeeeers
ur oem set is also a coilover set, u mean aftermarket full coilover replacement? As it states in full, u dun need anything else from oem except the mounts perhaps
Thanks guys :) Learning lots. If it's true that my current stock shocks will 'die' soon, I dont mind changing is sometime soon and sell of the current springs :)
wont up lorry that fast.....
cheeeeeeeeeeeeeeeeeeeeeeeers
