M gear shifter
Re: M gear shifter
The last time I helped another fellas get it installed at J4C, the installation cost alone was $80. Is that expensive?
Re: M gear shifter
sugi;518159 said:
any idea what would be the installation cost alone?
Mine arriving on 17 Feb.
Cant install immediately, i believe most outlet will be closed whole of next week.
Thanks
no idea on installation alone. was told by some1 in totality.
Re: M gear shifter
Installed yesterday.
Love the slick feel compare to big original gear knob.
The light indicator move as you shift from parking->R-N->D
Re: M gear shifter
very ice. congrats!
did u change the shift boot as well? looks smaller
Re: M gear shifter
Slater;521909 said:
very ice. congrats!
sorry what is shift boot?
is it the leather portion?
I am using back the original one cause the one i get cannot fit my e93.
Re: M gear shifter
yes the leather portion.
Re: M gear shifter
Confusing isn't it when the shift pattern on the console plate differs from the knob?
Re: M gear shifter
why or how will it differ? consol will still show the same position as the knob no?
Re: M gear shifter
Yes, if you shift to D, both the consol and the knob will show D. Sama sama.
But I think what ACS6 meant could happen if a new driver just hop into the car and try to shift the knob according to the shift pattern on the gear knob.
Re: M gear shifter
den u will just break the knob.
Re: M gear shifter
ya, i almost broke hitmee's knob ha ha ha. That's why I know there could be confusion, because i was confused. I noob. :p
Re: M gear shifter
Would be funny when a new driver tries to hit it into the R position on the knob....thinking there must be some combo (ala PS3 cheat code) to get it into that R position....R means RACING.....
Re: M gear shifter
Any idea which workshop can modify the stick to fit E90.
Seem that the boot for E90 is bigger and different shape from the round boot which come together with the stick.
Thanks.
Re: M gear shifter
Any workshop can wire it up for you....J4C, Boss etc.
Re: M gear shifter
One workshop quote SGD100 to install.
Is that normal price ?
For those already modified. Did you see the guy connect the white plug come with the stick directly underneath the boot or did he cut and piggyback with the wire attach to the current P/N/R/D light indicator.
If direct connection. Then easy can fix yourselves. But if need to piggback with the current wire. Better pay expert to do.
Re: M gear shifter
hi guys,
thinking of installing the shifter but am curious about the gear shifting.
does the original shift direction remain or does the direction go according to the ones displayed on the new m gear?
sorry i a bit blurr on it.
ray
Re: M gear shifter
Hi Sugi,
Where did you buy the gear knob? You bought it separately and asked someone to installed? Or you get the car mechanic to purchase and install at the same time?
Re: M gear shifter
Ken_Loh;529440 said:
Hi Sugi,
go to mike at SWC
Re: M gear shifter
jvhuiz;524070 said:
hi guys,
ray
It will change gears according to the original way. Btw, the M gear does not come with any button to press while changing gear.
vn88vnxcom
