Need advise to buy SETRAB OIl Cooler
Re: Need advise to buy SETRAB OIl Cooler
des, if you DIY yourself, how do you ascertain that you have achieved positive flow in your oil cooler?
Based on this: - is enough for me.
1) Oil Temp Guage was installed before and after the cooler. Indications showing a general 4-9degC . degrees cooler on average on normal operation AFTER installation. During raining conditions - drastic drop in temp(with cooler in).
2) Oil Pressure Measures at outlet valve was about 30+psi??.. enough to gush out spilling oil onto my entire ....nevermind. Wasted 2 litre in the process.
3) I have no confirmation of oil pressure pumping back at inlet. But only using (1). And as long as i see positive result, i am ok. Not a engineer la.....paisey.
4)Hose diameter and PT/JIC joints are all the same measurement along with the "cap" or whatever they call it. Only varies a little bit in angle and length and threading. Shouldnt differ by much I think? Anyway, I am reverting to tecnik kit as I want a bigger cooler to see better result. I hope???????
Racebred said:
well, while there isnt any magic involved, it's not that easy for a local workshop to trial and error on some customer's car until some positive flow occurs on any aftermarket oil cooler, and usually they dont have such confidence on self-R&D (on someone else's car), as was fedback to me.
Then I have to say it is a sorry shop that cannot understand where the pressure side is, where the return is, where the highest spots where air may collect, where to place any valving if needed, and then to tap the threads, get fittings and then plumb and/or valve these points with either straight single or switched-secondary.
I would like to see the day when a local workshop comes across a solution to a worldwide problem, solve it, and begin to market such products to the international market with repeatable performance and reliability.
Yes that will be great.
until such time, the customer must either have a lot of faith, or can afford a long downtime to R&D, or buy direct solutions from others who have already achieved it.
2 hours of sitting down with the car's factory manual and/or examining the stock car and planning, and 6 hours on a manual lathe and mill machining and you can have the basics done. All that is left is to order fasteners and hoses.
ok I will stop now..
