piggyboyz
Core Group Members
Arsony said:In the first place, if you use spacers, you will need to use longer screws! Logical what
Spacer is usually not recommended cos funny as it may be, u don find screw that will be slightly longer for that matter...
U will realised that when u buy rims, they come with the screws and this screw takes into the consideration the amount of thread you have at the hub and add on the amount of metal there is at the rim, working out the total length. If u add a spacer of say 6mm to push the rim sit wider, u effectively shorten the thread by 6mm and u will need a lot of luck to find screw that will be additional 6mm longer.....
Also by adding spacer, the geometry of the car is upsetted. The wheel sits on the outermost edge of the rear control arm, which is pivoted near to the centre of the car. Increasing the length ( in this case, further away from the pivot) will increase the moment arm of the pivot. The formula for Moment arm is F x length x length /2 and increase of 6mm is quite a fair bit to the additional moment taken by the arm since it's to the power of 2. And all these increase will be absorbed by the spring and shock, which also increases their stress level and in return, a shorter lifespan...
Also, the rear wheel sits at a negative camber of about 1 degree and that is with respect to the distance from the pivot of the control arm to the wheel hub and moving it further away increases the angle. This can of course be brought back to spec but u will have to work out the correct degree when the wheel has been moved out by the spacer thickness.
Last but not least, the material of the spacer is very important since if the material is weaker than the screw torque, the spacer might be effectively be compressed and if the 5 wheel nut is of different torque, then the spacer will be compressed at different degree and u might just ended up with the wheel not pointing straight and wobble during high speed.....
:roll:
