eric7107;1031605 said:5 Sept 2013 - Left car overnight at PML
6 Sept 2013 - Test car together with SA. Why i left it overnight? Cause the noise is the most audible in the morning especially after humps.
Findings:
PML says that the noise was coming from front right (driver side). They will replace with a new spring strut. However, I still find that the sound was emitting from rear sector. Their reason was that sound travels. Anyway, appt fixed next week. Will see how it goes after the replacement parts. I accept zero tolerance for lubrication proposal as that has been done before. Only last 1 mth.
Will keep you guys update
cheers!
Terras14;1033872 said:Hi guys my colleague 2011 f10 523 also has this clonking noise from his suspension in the morning. After driving a while and warm up, the noise is gone. Seems like all f10 has this issue. Anyone manged to solve this problem with pml?
Something must have worn out coz when the car is new, there wasn't any sound.... Pls keep us informed. My colleague also thinking of leaving his car overnight but based on your experience, it looks like pml cannot solve the problem. Please keep us informed k. Thanks n good luckeric7107;1034262 said:PML failed me again :errrrrrr:
Despite the replacement part at the front right spring strut, the noise was not eliminated!!
Haiz...dunno what to do now.
"Leaving my car again on Monday and they need to update car software...."
How to solve the suspension irritating noise.
I must admit that it's a small issue as after some drive and warm up, the noise will be gone.
But just "buay song" especially paid some much for the car!!
Need help.............
regards,
Eric7107
JuzMe;1034416 said:If car still under warrenty and PML does it for you for free, then bring to them (hahaha, probably need multiple trips). Else bring to R2D, he's one of gurus in finding annoying noise in cars![]()
Sounds like you have no choice but to pay to get it fix at another shop...eric7107;1034506 said:The main issue/problem we facing is that although the car is under warranty, we left it overnight umpteen times for them to test and they cannot address the issue!.....that's bad! They tried greasing, change front strut.....next don't know change what! We can't keep leaving the car in PML workshop for them to T&E.....wann trial and error until when...![]()
If PML can't solve it, why not MA?Terras14;1034405 said:Something must have worn out coz when the car is new, there wasn't any sound.... Pls keep us informed. My colleague also thinking of leaving his car overnight but based on your experience, it looks like pml cannot solve the problem. Please keep us informed k. Thanks n good luck
JuzMe;1034508 said:Sounds like you have no choice but to pay to get it fix at another shop...
regards,
Eric7107
detach8;1034623 said:What kind of sound?
Thunk?
Squeal?
Scrub?
I never heard any noise from my F10. In fact it is the quietest car I've ever owned. I even changed to M-sports. No noise.
The only noise is a scrub coming down from MSCP too fast, which is caused by a loose lower piece of cover just in front of the front wheels (for aerodynamics). Most F10s I know have this piece loose after rubbing our SG MSCPs.
eric7107;1034619 said:Leaving my car at PML today to address 2 issues:
1. Update car software issue (not a major issue and considered routine)
2. To address rear suspension sound especially in the morning (will just touch on this issue)
For issue 2, events as follows:
5 sept - left car overnight at PML
6 sept - tested car and SA say sound was from front right side. To replace with new spring strut. Appt fixed on 13 sept.
13 sept - replaced with new front right spring strut.
14 sept - rear sound squuezing was still audible. Recorded with iPhone memo voice recorder.
15 sept - rear sound squeezing was still audible. Recorded with iPhone memo voice recorder.
16 sept - morning sent in car for updating software and mainly to address the rear suspension sound. Let the SA and the technician hear the recorded noise. Could see ???from their silent expression. I proposed that the car parked overnight at nearby MSCP around deck 4. First thing in morning drive out from MSCP. Driving from PML to MSCP might not have that effects. Explained to me about safety as car outside PML. Accepted their reason. They now proposing to dismantle whole rear suspension and grease it... Leaving for another 2 to 3 days without car![]()
horrible;1036094 said:Can u describe e sound.
We try to brainstorm 101 causes
Did they check the exhaust?
