Offset and PCD for 116i
Derrrick Yap
Hi Guys,
Any idea on what is the Offset and PCD for 116i?
Re: Offset and PCD for 116i
PCD 120, stock offsets +49/+52 for 7.5/8.5 width.
Thanks guys for the info. Cheers :)
Same for 116i n 118i...
Front and rear same offset for f20?
18x8.5j offset45 using 245/35 r18 square setup ok for f20?
TIA
TIA
can but front Tyres use 225/40r18 better
Any reason why? Front will rub?
I prefer square setup for tyre rotation purposes.
Yes, front will rub on 245.
if you want to rotate, then rear use 225/40r18 also.
Ic thanks.
Which means front offset is less aggressive than the rear.
I prefer 245 for the back because so far the grip is perfect. During test drive, i loses abit of traction on 225.
ccc;914358 said:
Ic thanks.
No, it's bcoz front tyres must turn so the extra width can rub. Also, more drag if use to wide up front.
hi guys, can i use my 320 yr 2009 stargger on my 120i? coz trading in to dealer...many thanks in advance
Guys, dun think that F20 can only stick to very conservative fitment... Which were advised by alot of typical rims shop...
Singapore are rather conservative in their wheel mods...
A BMW 120i in China did it with...
front: 215/35R19 on 9J +30
rear: 245/30R19 on 10.5J +20
