Our daily ETC....................
BMW F25 X3 X35i came in to replace Electric Power Steering Rack.
Thank you for the support!
BMW F20 116d came in to fix oil leak issue. We replaced the valve cover and ride is good to go.
Valve cover is an important component on the engine. It keeps the pressure within the engine consistent. If there is a leak, pressure is somehow lost.
Thank you for the trust and support!
BMW F10 523i came in to replace his Valve Cover. We took the opportunity to also inspect the vanos screws. True enough, they we still the aluminium type and has a history of breaking. We replaced with steel screws and solved the problem.
BMW F33 428i came in to uograde to iDrive 6 with Apple Carplay & also fix all its oil & coolant leakage.
We also took the opportunity to replace the chain guides. It is important to replace them whenever possible as failure will lead to a big hole in the pocket.
BMW E89 s20i came in with air-conditioning problem. The cooling coil had to be replaced. It is a massive job but nothing is too difficult for us.
We were able to get up on time. All good and air-conditioning is cold again!
Thank you for the support & trust!
BMW F10 520i came in for some repairs. We were able to run thru all the issues with owner and made sure that owner understands. Nothing escape the eyes.
With that, owner will decide if they proceed with the stipulated jobs.
Thank you for the tremendous support & trust!
BMW M135i came in for some repairs. As we progress deeper into the scope of repair, we found out more and more problems.
We were able to sort out the imperfections others left behind. Most importantly, the car has go be in perfection condition when it leaves our shop.
Thank you for the trust & support!
hb88notforwall
