MTechnic
Re: Piggy back or reflash ECU- which is better
Care to share - what do you mean by methanol injection?
shlim;910021 said:Not quite true.... if you use Cobb Tuning, which is a ecu remap, it is stealth, you can remove anytime you want without opening the bulkhead cover, multiple piping and the ecu, no need to mess with wiring. AND you can resell the ecu remap.....
Basically the remap is done using a device plugged into the OBD port. Choose to install whatever maps you want or deinstall. ANd it's licensed based on one device = one car. So when you deinstall you can sell the device (called an AccessPort).
However, if you are an advanced modder and is going for methanol injection, then the piggybacks are the only way to go... Cobb Tuning being ecu remap cannot control the meth injection directly.
