pml bring in 318??
Re: pml bring in 318??
Hi XCLR8,
FYI just in case you miss this thread:
318i made in Germany
320i made in South Africa
Probably can do a re-mapped to match the power of 320i
yes 318i and 320i indeed shared the same engine but the 318i is actually 143hp and 190nm..... vs 320i: 150hp and 200nm (156hp and 20 0nm)
some items that don't come along with the 318i are: XL (high beam and low beam), arm rest front sliding, automatic air-conditioning, rear passenger air-con vent, different leather, headlight washer system, interiror rear-view mirrors with automatic anti-dazzle function...
you are right you pay for what you get......so this are all the items that 318i owner will not be getting............unless they go for the 320i......so for 20k it should be worth it to have all those goodies/extras for the 320i.......
Probbaly you can say 320i is the highline version vs the normal 320i (which is 318i)
ac323;462025 said:
FYI:
The 323 and 325 shares the same engine and same intake manifold, however the 325 runs at much higher compression ratio. I supposed this is possible through different engine mapping by giving more intake and exhaust valve overlap, thereby reducing the engine compression.
323 & 325 has different DISA (differential intake system). Check out REALOEM. DISA for N52B25 is supposed to be 3 stage. Mayb 323 has only 2 stage.
It is the same for 318 & 320.
Do you think there is a difference in the country of make? Does Germany made means better fit and finish against S.Africa? If not wrong, only 335i and the higher series are made in germany. Sounds like bonus that basic 318i is made in germany.
What color is your new ride? Believe you must be really excited...
Hi XCLR8,
i just collected my Alphine White 318i on 26 July (still enjoying it)
my E89 is Black with red interior.........(ok ok.......waiting for delivery)
PM me your number maybe can go collect car together.......
The new 335i I bought from PML this year was assembled in Dec 2008 in South Africa.
So far so good except driver door a bit hard to close.
Hi ktnpl,
wow....335i power man..................
ac323;462115 said:
Hi ktnpl,
hi ac323
car is power but I drive very gently lol
nice avatar - is that your car? looks hot!
kt
Hi ktnpl,
yes but collecting only on 22 Aug (i hope no delay)
Thanks and cheers.........
ac323;462016 said:
Hi wt_knows,
as comparing 323i and 325i (the power definitely alot of difference, 177hp or 190hp vs 218hp) - any 323i / 325i owner out there care to share / to clarify......?
cheers..............
Bro, the FL 323i has 190 hp and 230 nm.
ac323;462016 said:
Hi wt_knows,
Bro, the FL 323i has 190 hp and 230 nm. :D :D :D
Hi bmw_newbie,
oh i see so is the pre (FL) 177hp?
XCLR8;462083 said:
Booked 318i a week ago and thinking of changing to 320i. Does PML allow it and in terms of discount, will ther be more for 320i than 318i. or the same?
Bro,
It depends when you confirmed your 318i. Did your 318 factor in the price increase of 5k? If it did, negotiation may be easier. But nevertheless, dont expect the best deal for your 320 becos PML has no obligation to give you more discount than you are entitled as it has your 12k deposit in their bag! :furious: :shoot: :shoot:
I'm not an expert in car engine but this explanation sounds logical, assuming 318 has only 2 stages and 320 has 3 stages, then it would be impossible for 318 to remap to 156 bhp.
Hi achee,
you are right that's why can only re-mapped to close to 320i........
Even wif 320 DISA, i don't think it is that easy to re-map to 156bhp. This is because ECU has to built in the activation point for all 3 stage.
ac323;462023 said:
Hi Mike218,
Take-out spare tyre (reduce weight)
GrupeeM
Headers
Exhaust
Volker Spec II plugs
Ivac
Coil Booster
Velocity (latest version of sprint booster)
finally do a ECU re-flash (should be able to squeeze out max 20hp)
happy modding (MTL)
remember to improve the handling after that: KW v3 plus H&R sway bar
BBK?
Hi Bro Alv,
Velocity basically cheats the ECU to boost the pick up, but no ponies are added. But the rest definetely does. Plus can change airfilter and air scoup too.
Btw, will I be see you on Sat bro?
Try to make it lah....
achee;461956 said:
Was having this question in my mind and see if any bros can help to answer.
Many bros commented that 318 is in fact the same engine as 320 (I agree with this), just that it is detuned to achieve 136 ponies instead of its original 156 ponies and the buyer can then increase the ponies in an aftermarket by remapping etc. Why would BMW AG want to deliberately depress its ponies if it is supposed to achieve higher?
Bro,
Its marketing tactic, IMHO.
Its probably out to rival Benz's new C160....
wt_know;462022 said:
based on your theory,
BMW could separate 323/325 and 523/525 by its equipment and quality (ie: leather quality, memory sets, xenon lights, electronics, idrive,with & without bodykit, etc) -> it is simple, isn't it ?
so, why choose the route to detune the engine ? it is quite simple, you have to pay more for more power :D
Hi Bro,
Its all marketing stretegy to rival the Benz..... But I think they didn't do an excellent job.... as the new C160 has an edge over the 318 for slightly better equipments. But for the same $$, I still go for the Bimmer.
Just my 2 cents worth
Bro,
320 shl have higher discount.... Go check with your SE.
