Terras14;896658 said:Hi, was told by the sa that they use shell w30 oil n its a special blend not for retail. Anyone know what oil is that? Also any other recommended oil for n20? Thanks
wt_know;896671 said:probably castrol edge 5w30?
evilbear8;896835 said:They might be using Shell Helix Ultra AB. QAF, Brunei's equiv of PML uses that oil for the n20s. Considering Brunei BMW gets their stuff from SG, wouldnt be surprised if you guys use the same.
Both brands are in use for authorised BMW service centres.pReTeNd3r;896721 said:They still using castrol edge 5w30? tot they change to shell helix ultra
pReTeNd3r;896868 said:I support mobil ...
Ct13;896884 said:Mobil 1 or Mobil 1 gold?
Baby1M;896854 said:Special blend of Shell engine oil for N20? Frankly, kana big smoke by SA because the SA does not know the specific Shell Helix engine oil being used.
If it is Shell w30 or Shell Helix Ultra, then it is definitely one of the three below:
- Shell Helix Ultra 5W-30 (cleans and protect for Shell's maximum performance)
- Shell Helix Ultra E 5W-30 (for improved engine efficiency)
- Shell Helix Ultra Extra 5W-30 (helps protect emission system of exhaust after-treatment devices)
What special blend that is not for retail... TCSS only and they can TCSS because most car owners are 'not in e know'... goodness sake, this is the Internet Era, what is e SA thinking?
Not forgetting HTHS > 3.5 hor. Not all 30wt oil meet this requirement.Baby1M;896857 said:As long as it meets/exceeds the Viscosity grade stated by BMW, it should be good to go.
I understand.davidtch;897920 said:Not forgetting HTHS > 3.5 hor. Not all 30wt oil meet this requirement.
Still got Mobil 1 Gold meh?Ct13;896884 said:Mobil 1 or Mobil 1 gold?
Terras14;898338 said:Thanks for the detailed info. So for F10 N20 must meet LL01 or LL04?
I am confused liao...thanks in advance
LL-04.Terras14;898338 said:Thanks for the detailed info. So for F10 N20 must meet LL01 or LL04?
Since N52, only LL01-FE or LL-04.pReTeNd3r;898346 said:Both also can
