Pml engine oil for n20
Re: Pml engine oil for n20
Anyone tried Castrol 5w40 on 520 n20? Ok to use 5w40 for 30k km servicing? I was on mobil 0w40 previously.
i tried Q8 5w-40 before on my (X1 20i) N20. no problem. quite smooth.
stylistic;935679 said:
Actually to be exact it's 0.75l more than the N46. N46 uses 4.25l, whereas the N20 is a 5l :)
Yup.. Have u tried 4.5L? The oil measuring probe would likely to tell u max level.
How much is the engine oil volume needed?
Yup by right 4.5l should tell you 'max' to.. But technically if u were to have additional 250ml of oil in your engine, the engine wouldn't be as responsive due to having to overcome the additional volume in the sump. That's what i think though. So since it's 4.25l, why add in additional 250ml unless you are having oil leaks? HAHA
pg888lat2024
