Probably the 1st in the world
Re: Probably the 1st in the world
not necessarily, desmond. at track conditions, my AP 6 pot + semi slicks combi, effectively cancelled out ABS. If i brake hard, the wheels are actually allowed to lock up and i lose traction. Actually even with street tyres, there's enough braking force generated to overcome the ABS program too.
I actually subconsciously did treshold braking in sepang when the ABS disappeared. I didnt even notice my ABS was missing until Welbo did a taxi ride in my car and told me my ABS disappeared, and I had subconsciously adjusted my braking to suit.
In a subsequent experiment, by giving 100% braking, the wheels locked up and the car just glided forward. But back in a non-track condition, during wet braking on the street, the ABS returned.
So, my conclusion is, I dunno what the hell happened to the BMW ABS system, or how the parameters hold up inside, but if you mod your brakes, you better know how to drive around the changed conditions to suit. Never rely fully on the electronics.
On this note, i'd like to give some more advise on modding your car vs changed BMW electronic parameters. People who have modded their powertrain, or their ECU, should take note that the traction control programming involved in matching the ECU map to the autotrans are now no longer properly "speaking" to each other.
where originally, downshifts, and steering inputs involve some form of traction control, your car will be prevented from spinning off to death when you do a downshift in the middle of a corner. In modified cars, you run a very very (very) [very!!] freaken high risk of getting into a shift lock situation, where there now is a sudden torque change to your rear wheels while downshifting due to lack of traction control arising from anyone modding their cars.
If you are not prepared to do a full countersteer, you will spinout. This scenario can even happen on enthusiastic street driving situations where the kerb is just half a lane away. You have been warned.
I have had extensive experiences with the above 2 scenarios i listed, on the E46 chassis and electronics. Pls be careful when you mod or tinker with anything that's been properly designed out of the factory. Be a learned and informed modder, and safe driving to everyone.
Never take your license when you play GT4 right???!!!!ha ha. It basically means you have to stomp on your brakes and achieve the minimum distance for your car to comes to a complete halt. This only can be applied to people with ABS because it is actually the point where MAXIMUM braking is achieved before the wheel locks. If you do not have ABS and you know that braking point each and everytime before the wheel locks - you dont need ABS, you are KING!
Another way to look at it is "What is the TRESHOLD of pain you can take before you finally give in?" or the treshold of tolerance before you crack or shouting out the password when your BDSM mistress spank you too hard.ooops Ouch. Anyway, you get the idea? :)
DreamDriver said:
May I know what "threshold braking" is?
Aiya I don't play GT4 what. So I don't know mah. Anyway thanks for clarifying!
BTW you don't read PM ah? Never reply me..
BlackStealth said:
Never take your license when you play GT4 right???!!!!ha ha. It basically mean you have to stomp on your brakes and achieve the minimum distance for your car to comes to a complete halt. This only can be applied to people with ABS because it is actually the point where MAXIMUM braking is achieved before the wheel locks. If you do not have ABS and you know that braking point each and everytime before the wheel locks - you dont need ABS, you are KING!
Threshold braking is braking on the threshold of wheel lock. It is a fast but measured process, certainly not stomping. Never stomp on the brakes when performance driving, ABS or not.
Threshold braking is done on cars without ABS. On cars with ABS, threshold braking can still be performed.
There are drivers who are consistently stop in shorter distances in the dry without ABS as well as turn better laptimes. In the wet, most tend to prefer ABS because it the brakes lock up a lot easier. If brake force could be calibrated for the wet, requiring dry lock pedal pressures to reach wet lock brake force, then perhaps they would prefer no ABS as well.
It is easier for an untrained person to stomp on the brakes rather than attempt quick roll on the brakes - especially in a pure surprise emergency situation. This is separate from performance driving though.
Your Axxis Ultimate pads and StopTech braided SS hoses
TripleM said:
It has Stop Tech ss brakeline and Axxis Ultimate brake pads.
Kudos to Ah Wee of BVO for the superb work :)
I bought Axxis Deluxe+ frt brake pads from Zeckhausen Racing, who got StopTech to drop ship the Ultimate pads to me because he was out of stock. The Ultimate pads are not for me but for a rather more aggressive 530i (black sapphire, 3 digit #) owner who shall go unamed. He always fulfills his need for speed, so he needed better, more fade resistant stoppers.
I ended up ordering a set of front and rear braided SS brake hoses from StopTech for my E60 since they were so nice on the phone and were willing to make up a set on the spot for me. Cheap bling.
Here are my questions: How long will Ah Wee take to change the front pads and front & rear brake hoses (and all the bleeding work) on my E60? Can you recommend any particular brake fluid, or should I just use the stock stuff. Car only has 4,700kms since new and I don't intend to track the car.
On a slightly different topic, I presume BVO is the place for other transmission related mods? I need to install my UUC Evo3 SSK, and a modified CDV as well. Is Ah Wee the guy with the titanium wrench?
Thanks
Re: Your Axxis Ultimate pads and StopTech braided SS hoses
Thanks
Yep, he is the guy who can sort you out
Brake fluid wise, just use a normal one...No need for the high temp 5.1
Time needed to do the pads n line should be 3 hrs max and whle you are there, u can always hang out at the opposite kopi joint while waiting
Im sure there will be some people from the forum whom you can chat with :)
Gd luck
Axxis Ultimate/Deluxe plus, StopTech SS hoses, H&R Coilover
Gd luck
Too late, I already bought 3 btls of Motul RBF600 since the product specialist at StopTech recommended it. No harm using higher spec brake fluid than necessary I suppose.
While I'm there, I might as well install the H&R Coilover Suspension Set which I received today. I guess I'll have to leave my car there for a few days.
Are there forummers hanging around BVO all day, everyday? That's quite worrying and heartwarming at the same time.
Re: Axxis Ultimate/Deluxe plus, StopTech SS hoses, H&R Coilover
Cool, do it all there...
If u call em up and make a booking , u can have it all done in a day I am sure
Yep, no harm in using that Motul brake fluid..
Congrats on all the mods
Do give us review on how the H&R performs on 5series
Probably the 1st in the world-The Sequel
Finally the M3 brakes are all in...
Thanks to Ah-Wee at BVO who had been really patient and focused in doing the job.
No more braking bias. Still running in the rear brake as we speak...
Here are some pix together with my formerly-remembered-bronze rims but resprayed now to silver/hyperblack-ish tone. Kudos to Yew Lip too for that :)
Enjoy lads
Nice picture quality but how come you only took pictures of your own car last Sunday? We were there too you know....knn. We really need you to do another group photo taking for us soon.
i got ur pix with middle finger shown, i send to u tomorrow ok ?
U selling? Cos I'm buying..kekekeke
Re: Probably the 1st in the world-The Sequel
Enjoy lads
Swee Swee... throw in the Hamann Indicators lagi Swee!!
What would u like to buy, my fren?
Oh yes...thanks to you especially for the flr matt. It completes the interior.:yummie: :inlove:
Glad u like them Pak!! by the way, hw come your passenger floor matt diff?? The "Hamann" logo in near center? I thot both on the side?????
It's on the side like the driver's one.
Were u standing on your computer screen n looking down hence it looks like in the center?
