Re: DIAGNOSE + CODING anytime!!! (Seats Belt reminder, Remote Code, Digi Speedo.etc)
ALSO, check out the codings we can do on our ride... mine is e60 525i
Available codings:
Kindly note: Whether each coding actually shows an effect depends on the specific model and the available hardware.
CAS: Comfort start
active
not active
BMWhat: Ignition key just has to be tapped once to start the engine after ignition is turned on.
CAS: Comfort eject
active
not active
BMWhat: Ignition key is automatically ejected, when ignition is turned off.
CAS: Comfort open using remote
active
not active
BMWhat: Press and hold the unlock button on the remote to open all windows and the sunroof. Convertibles open the roof instead.
CAS: Comfort close using remote
active
not active
BMWhat: Press and hold the lock button on the remote to close all windows and the sunroof. Convertibles close the roof instead.
CAS: Comfort open using keylocks
active
not active
BMWhat: Unlock the car by key and hold the key in the unlock position to open all windows and the sunroof. Convertibles open the roof instead.
CAS: Comfort close using keylocks
active
not active
BMWhat: Unlock the car by key and hold the key in the unlock position to close all windows and the sunroof. Convertibles close the roof instead.
CAS: Comfort folding/unfolding for sideview mirrors
active
not active
BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. To activate this function please activate "Comfort folding/unfolding for sideview mirrors" in the "FRM" module.
CAS: Easy entry
active
not active
BMWhat: Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 1
active
not active
BMWhat: Separate setting for "Easy entry" for key 1. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 2
active
not active
BMWhat: Separate setting for "Easy entry" for key 2. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 3
active
not active
BMWhat: Separate setting for "Easy entry" for key 3. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 4
active
not active
BMWhat: Separate setting for "Easy entry" for key 4. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Selective central locking
active
not active
BMWhat: Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 1
active
not active
BMWhat: Separate setting for "Selective central locking" for key 1. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 2
active
not active
BMWhat: Separate setting for "Selective central locking" for key 2. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 3
active
not active
BMWhat: Separate setting for "Selective central locking" for key 3. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 4
active
not active
BMWhat: Separate setting for "Selective central locking" for key 4. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Daytime running lights (US)
active
not active
BMWhat: Value01: Turn signals are used as daytime running lights. Value02: Dimmed high beams are used as daytime running lights.
CAS: Heckklappe sperren bei verriegeltem Fahrzeug
active
not active
BMWhat: Heckklappe kann nicht entsperrt werden, wenn das Fahrzeug abgesperrt ist.
CAS: Automatically lock vehicle Key 1
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 1. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 2
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 2. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 3
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 3. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 4
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 4. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Lock vehicle upon ignition
active
not active
BMWhat: Vehicle is locked, when ignition is turned on.
CAS: Unlock car when turned off
active
not active
BMWhat: Doors are automatically unlocked, when ignition key is ejected. Only works if "Lock vehicle at x kph Key 1-4" is activated.
CAS: Threshold speed for vehicle locking
value 01
value 02
value 03
value 04
value 05
value 06
BMWhat: Sets the speed at which the vehicle automatically locks all doors. For models other than E46 values 1 to 6 mean the following: 4 kph, 8kph, 12 kph, 20 kph, 24 kph, 28 kph To activate this option you need to activate "Lock vehicle at x kph" for the according keys.
CAS: Lock vehicle at x kph Key 1
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 1 is used.
CAS: Lock vehicle at x kph Key 2
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 2 is used.
CAS: Lock vehicle at x kph Key 3
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 3 is used.
CAS: Lock vehicle at x kph Key 4
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 4 is used.
CAS: Interior lights with remote
active
not active
BMWhat: Pressing the lock button on the remote, when the car is already locked, turns on the interior lights.
CAS: Panic mode remote
active
not active
BMWhat: Press and hold the "unlock trunk" button to trigger the alarm.
CAS: Unlock rear window
active
not active
BMWhat: Key unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 1
active
not active
BMWhat: Key 1 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 2
active
not active
BMWhat: Key 2 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 3
active
not active
BMWhat: Key 3 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 4
active
not active
BMWhat: Key 4 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window with outside trunk lid button
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models.
CAS: Follow me home lights duration Key 2
active
not active
BMWhat: Separate setting for duration of follow me home lights for key 2. Values 1-5 are codable: 0 sec., 40 sec., 90 sec., 150 sec., 240 sec. If only values 1-4 are available: 40 sec., 90.sec., 150 sec., 240 sec.
CAS: Follow me home lights duration Key 3
active
not active
BMWhat: Separate setting for duration of follow me home lights for key 3. Values 1-5 are codable: 0 sec., 40 sec., 90 sec., 150 sec., 240 sec. If only values 1-4 are available: 40 sec., 90.sec., 150 sec., 240 sec.
CAS: Unlock rear window with outside trunk lid button Key 1
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 1.
CAS: Unlock rear window with outside trunk lid button Key 2
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 2.
CAS: Unlock rear window with footwell switch
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models.
CAS: Unlock rear window with outside trunk lid button Key 3
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 3.
CAS: Unlock rear window with outside trunk lid button Key 4
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 4.
CAS: Unlock rear window with footwell switch Key 1
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 1.
CAS: Unlock rear window with footwell switch Key 2
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 2.
CAS: Prohibit engine start without brake
active
not active
BMWhat: Engine can"t be started when brake is not pressed.
CAS: Power windows switch-off condition
active
not active
BMWhat: When this option is activated (us in E46) the windows are switched off immediately after the ignition is turned off. When deactivated (ece in E46) the windows are active for another minute.
CAS: Arm/Disarm Anti-Theft Alarm System
Only with remote
With locks and remote
BMWhat: Anti-theft alarm system is armed/disarmed by locking/unlocking the car (1) with the locks and the remote or (2) only by locking/unlocking the car with the remote.
IHKA: Save circulation settings
not active
active
BMWhat: Circulation settings are saved for next start of the vehicle.
IHKA: Air conditioning engine speed
not active
active
BMWhat: Increase idle engine speed when air conditioning is turned on.
IHKA: Blower level during automatic air conditioning
not active
active
BMWhat: The current blower level is displayed even during automatic mode of the air conditioning.
IHKA: Automatic compressor with air conditioning
not active
active
BMWhat: When pressing the "Automatic" button for air conditioning, the air conditioning does not start by itself.
IHKA: Ventilation in off-mode
not active
active
BMWhat: Ventilation blows on smallest level, when air conditioning is in off-mode.
IHKA: Off-Mode Memory Key 1
not active
active
BMWhat: Save setting for "Off-mode" for the air conditioning. Separate setting for key 1.
IHKA: Off-Mode Memory Key 2
not active
active
BMWhat: Save setting for "Off-mode" for the air conditioning. Separate setting for key 2.
IHKA: Off-Mode Memory Key 3
not active
active
BMWhat: Save setting for "Off-mode" for the air conditioning. Separate setting for key 3.
IHKA: Off-Mode Memory Key 4
not active
active
BMWhat: Save setting for "Off-mode" for the air conditioning. Separate setting for key 4.
KOMBI: Digital speedometer
not active
active
BMWhat: Digital speedometer is displayed in dashboard. This option does not work with every model yet. If there is no digital speedometer available after coding this option, please set this option back to not active and send that log.
KOMBI: Digital speedometer correction
not active
active
BMWhat: Active: corrected speed is displayed in dashboard Inactive: true speed is displayed in dashboard
KOMBI: Speedometer correction
not active
active
KOMBI: Speed limit warning
not active
120 kph
BMWhat: Speed limit warning at 120 kph is active/not active.
KOMBI: GPS time correction
not active
active
BMWhat: Time of day is corrected by using GPS.
KOMBI: Blank line in dashboard
not active
active
BMWhat: Blank line in dashboard is displayed/not displayed.
KOMBI: Permanent speedometer lighting
not active
active
BMWhat: Speedometer is always lit, even in the daytime.
KOMBI: Ignition key warning
not active
active
BMWhat: Ignition key warning active/not active.
KOMBI: Seat belt warning
not active
active
BMWhat: Various settings for the seat belt warning.
KOMBI: Seat belt reminder driver
active
not active
BMWhat: Seat belt reminder for driver is active/ inactive.
KOMBI: Seat belt reminder passenger
active
not active
BMWhat: Seat belt reminder for passenger is active/ inactive.
LMA: Flasher with bi-xenon
not active
active
BMWhat: Bi-xenon lamps are used for flasher.
LMA: Front fog lights and high beams not simultaneously
not active
active
BMWhat: Front fog lights are automatically turned off when activating high beams.
LMA: Follow me home lights - turn signals front
not active
active
BMWhat: Follow me home lights for turn signals front are active/not active.
LMA: Optical confirmation for unlocking vehicle
not active
active
BMWhat: Optical confirmation for unlocking vehicle is active/not active.
LMA: Follow me home lights - inner tail lights
not active
active
BMWhat: Follow me home lights for inner tail lights are active/not active.
LMA: Front fog lights and flasher not simultaneously
not active
active
BMWhat: Front fog lights are automatically turned off when activating flasher.
LMA: Optical confirmation for unlocking vehicle Key 1
not active
active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 1.
LMA: Optical confirmation for locking vehicle
not active
active
BMWhat: Optical confirmation for locking vehicle is active/not active.
LMA: Optical confirmation for unlocking vehicle Key 2
not active
active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 2.
LMA: Optical confirmation for unlocking vehicle Key 3
not active
active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 3.
LMA: Optical confirmation for locking vehicle Key 1
not active
active
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 1.
LMA: Comfort standing light 1/2
not active
active
BMWhat: If the light switch is set at automatic or on, the standing lights remain on, until the vehicle is locked with the remote. If this coding is activated, you have to set "value 01" for "Comfort standing light 2/2" additionally.
LMA: Comfort standing light 2/2
value 01
value 02
value 03
value 04
BMWhat: Only change this coding, if you change "Comfort standing light 1/2".
LMA: One-touch turn signal function
value 01
value 02
BMWhat: Number of turn signals when tapping the turn signal. Value 01 resembles one turn signal, value 02 resembles three turn signals.
LMA: Optical confirmation for locking vehicle Key 2
value 01
value 02
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 2.
LMA: Optical confirmation for locking vehicle Key 3
value 01
value 02
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 3.
LMA: One-touch turn signal function Key 1
value 01
value 02
BMWhat: Number of turn signals when tapping the turn signal. Value 01 resembles one turn signal, value 02 resembles three turn signals. Separate setting for "One-touch turn signal function" for key 1
LMA: Daytime running lights (Europe)
not active
active
BMWhat: Daytime running lights (Europe) active/not active.
LMA: One-touch turn signal function Key 3
not active
active
BMWhat: Number of turn signals when tapping the turn signal. Value 01 resembles one turn signal, value 02 resembles three turn signals. Separate setting for "One-touch turn signal function" for key 3.
LMA: Daytime running lights (Europe) Key 0
not active
active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 0
LMA: Daytime running lights (Europe) Key 1
not active
active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 1
LMA: Sidemarker (US)
not active
active
BMWhat: Sidemarkers are permanently active. May need additional "Sidemarker (US)" options set to "active" if available.
LMA: Selective central locking - unlock fuel lid
not active
value 01
value 02
BMWhat: The fuel lid is also unlocked upon the first unlock, when "Selective central locking" is active.
LMA: Daytime running lights - high beams brightness
value 01
value 02
value 03
BMWhat: Brightness for "Daytime running lights high beams".
LMA: Daytime running lights (Europe) Key 2
not active
active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 2.
LMA: Daytime running lights (Europe) Key 3
value 01
value 02
value 03
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 3.
LMA: Daytime running lights (US)
Daytime running lights (US) brightness
Brightness for \'Daytime running lights (US)\'. Value 01: off\nValue 02: bright\nValue 03: dark
Daytime running lights customization
Customization of the daytime running lights.
Off
BMWhat: Use dimmed turn signals as daytime running lights. To activate this option, set the brightness to bright or dark.
LMA: Daytime running lights customization
Off
BMWhat: Customization of the daytime running lights.
LMA: Turn signals (US)
not active
active
BMWhat: High beams
value 01
value 02
value 03
value 04
BMWhat: Brightness for "Daytime running lights high beams". Value 01: medium Value 02: bright Value 03: very bright
LMA: Brightness of Corona rings for daytime running lights.
Welcome lights - breaking lights
low
high
Standing lights - Corona rings brightness
Daytime running lights - Corona rings brightness
Brightness of Corona rings for standing lights.
BMWhat: off
LMA: medium
Breaking lights are turned on with welcome lights.
Brightness of Corona rings.
BMWhat: very high
LMA: Welcome lights - standing lights rear
BMWhat: Standing lights rear are turned on with welcome lights.
LMA: very low
BMWhat: low (standard)
LMA: Activate follow me home lights
not active
active
BMWhat: Follow me home lights are active/not active.
LMA: Follow me home lights with remote
not active
active
BMWhat: Quickly press the "Open trunk" button twice to activate the follow me home lights. Under some circumstances the option "Panic mode remote" in the CAS has to be activated, too.
LMA: Follow me home lights duration
value 01
value 02
value 03
value 04
value 05
BMWhat: Duration of follow me home lights. To activate follow me home lights, activate the flasher, while the enginge is off. Values 1-5 are codable: 0 sec., 40 sec., 90 sec., 150 sec., 240 sec. If only values 1-4 are available: 40 sec., 90.sec., 150 sec., 240 sec.
value 01
value 02
value 03
value 04
value 05
BMWhat: rather low
LMA: rather high
value 01
value 02
value 03
value 04
value 05
BMWhat: very low (standard)
LMA: Follow me home lights duration Key 1
value 01
value 02
value 03
value 04
value 05
BMWhat: Separate setting for duration of follow me home lights for key 1. Values 1-5 are codable: 0 sec., 40 sec., 90 sec., 150 sec., 240 sec. If only values 1-4 are available: 40 sec., 90.sec., 150 sec., 240 sec.
LMA: Cancel follow me home lights
active
not active
BMWhat: Follow me home lights are cancelled, when activating the flasher again.
LMA: Extend follow me home lights
active
not active
BMWhat: Follow me home lights are displayed longer, when activating the flasher again.
active
not active
LMA: Daytime running lights (US) dimming
active
not active
BMWhat: Dim value for "Daytime running lights (US)". Wert01: 26% Wert02: 40%
LMA: Follow me home lights - low beams
not active
active
BMWhat: Follow me home lights for low beams are active/not active.
not active
active
BMWhat: Follow me home lights for turn signals are active/not active.
LMA: Follow me home lights - dashboard lights
not active
active
BMWhat: Follow me home lights for dashboard instruments are active/not active.
not active
active
LMA: Follow me home lights - high beams
not active
active
BMWhat: Follow me home lights for high beams are active/not active.
LMA: Follow me home lights - number plates
not active
active
BMWhat: Follow me home lights for number plates are active/not active.
LMA: Follow me home lights - fog lights rear
not active
active
BMWhat: Follow me home lights for fog lights rear are active/not active.
LMA: Follow me home lights - fog lights front
not active
active
BMWhat: Follow me home lights for fog lights front are active/not active.
LMA: Follow me home lights - reversing lights
not active
active
BMWhat: Follow me home lights for reversing lights are active/not active.
LMA: Follow me home lights - tail lights
not active
active
BMWhat: Follow me home lights for tail lights are active/not active.
LMA: Follow me home lights - turn signals rear
not active
active
BMWhat: Follow me home lights for turn signals rear are active/not active.
LMA: Follow me home lights - parking lights
not active
active
BMWhat: Follow me home lights for parking lights are active/not active.
active
not active
BMWhat: Use high beams as daytime running lights. To activate this option, set "Daytime running lights" to "High beams".
not active
active
LMA: Welcome lights
not active
active
BMWhat: Welcome lights are turned on, when vehicle is unlocked.
LMA: Welcome lights Key 1
not active
active
BMWhat: Separate setting for "Welcome lights" for key 1.
LMA: Welcome lights Key 2
not active
active
BMWhat: Separate setting for "Welcome lights" for key 2.
LMA: Welcome lights Key 3
not active
Welcome lights Key 4
Separate setting for \'Welcome lights\' for key 4.
BMWhat: Separate setting for "Welcome lights" for key 3.
not active
LMA: Welcome lights - low beams
not active
BMWhat: Low beams are turned on with welcome lights.
LMA: Welcome lights - turn signals front
not active
BMWhat: Turn signals front are turned on with welcome lights.
not active
LMA: Welcome lights - turn signals rear
not active
BMWhat: Turn signals rear are turned on with welcome lights.
LMA: Welcome lights - number plate lighting
not active
BMWhat: Number plate lights are turned on with welcome lights.
not active
LMA: Welcome lights - front fog lights
not active
active
BMWhat: Front fog lights are turned on with welcome lights.
LMA: Welcome lights - corner LEDs
not active
BMWhat: Corner LEDs are turned on with welcome lights.
not active
