davidtch;988391 said:If brake pad hard, rotor will wear out fast.
If rotor hard, brake pad will wear out fast.
When i was driving E39, i used Textar pad & Brembo Max rotor. Pad at least 40k. Brembo Max is lighter than stock rotor.unfit;988394 said:Both my rotor and pad of E60 got to change every 30k km...Haiz!!!
Euphoria;988422 said:May I ask how much do the stock rear brake pads cost?
Centurion9990;988446 said:I just checked... PML $550... workshop below $300...
Same here.Radon39;988430 said:i seldom use brakes....
Scare?Euphoria;988451 said:Thank you.
Just wondering if my warranty will be void if I replace my brake pads outside of PML?
davidtch;988482 said:Scare?
Go to PML/MA.
LimPeh;988581 said:I drive my E60 for 9+ years and never had to change rotors. Had to change my brake pads and sensors around 30K km too.
ferri;988555 said:I did my rear brake change 2 weeks ago from PML cost was @ $495
unfit;988699 said:That's why I wonder LCI E60 rotor got worn out faster than the Pre FL issit...
Again PML SA said it is normal to change pad n rotor every 30k km...Haiz...
LimPeh;989260 said:Definitely not normal to change brake rotors every 30K km, something must be wrong or misaligned that could cause the rotors to wear out so fast.
My rotors were still good at close to 200K when I sold my previous beeeeemer.
The sensor is a separate item.horrible;989920 said:Does the stock pads come with brake sensor which is integrated into the pads or a separate part?
