fgchong;426651 said:Need advise on how to remove the leaves stuck at the bottom of the radiator.
Thank you in advance. FG
Samuel Tan See Teng;426657 said:Not sure, can try vaccum cleaner?
como;426974 said:i just use a hose to spray at the radiator, most of the time they will come out....
i wash the car every week so the leaves will come out pretty easy
centurion;426945 said:just cut 12" hose and attach to vaccuum cleaner and suck. Do it today. They corrode the radiator.
the leaves do fall off from the radiator area but does it actually get collected somehwere at the bottom? i.e, does it get flushed out from the car? Does not look like there are any outles below.como;427013 said:i will think if u wash ur car every week, the leaves will be out pretty easy by using a hose to spray at the radiator.
tatsit;427169 said:i use my fingers to take the leaves out one by one...
Herman;427176 said:... Den like what tatsit said... Use fingers lor.
