Replace rear brake pads
Re: Replace rear brake pads
abnertan;1093264 said:
Just changed at MA last Friday. My service alert light shows up telling me to change rear brake pad. I was then at around 49km.
Was quote 1.2k for rear brake and disc change by pml. Must brake gently in future haha
Why not change outside??
still within warranty n went back for servicing. anyway they measured the disc say still quite thick so just change brake pad.
i realise after change real brake pad, my service interval is reset to 35k. is this standard or up to the person doing it? how does the brake sensor work in tellfng us when to change when idrive will promt once it is near 35k
thanks
Terras14;1094697 said:
outside anyone knows how much?
Brakes dont cost so much to replace if you know where to buy from, do drop me a PM for pricing. (Please provide Vin number or number plate)
F10 rear pads, rotors & Sensor ?
$475 Nett Original BMW parts
$335 Nett OEM parts
Eng Soon Auto - Your BMW Oem Parts Specialist
$335 Nett OEM parts
That's for a pair of pads,rotors and wear sensor?
Your eom and original same manufacturer?
Yes for the rear axle, The brands we carry are OEM for BMW pads, however different series have different OEM brands.
But not to worry on quality as these brands are all world renown.
I changed my rear brake pad ard 28000 Kms.. Costs was $230 + labour $60..
All original parts box I saw..
with sensor complete set all in... Will not reach $1200...
Yep.. Display fault code prompt you to change.. Should be around 20 plus to 30 plus
thousands.. Cant be too far away..
Something wrong somewhere... I know of many F10's all 20 plus K only..
Unless brake pads changed to other types... or yours not new F10's.. Strange..
No, i did not use Autohold.. So very strange.. Just normal braking..
And i hardly do hard driving.. just soft driving.. haha..
Its not how hard you drive. Its how hard you brake.
if everyday drive in the city then brakes sure fade fast...
But then again, nowadays highways also same as city. Jam everyday and night.
You are driving a 1.5 ton car. It takes more braking force as compared to lighter weight car.
I took my brand new car for 1st servicing and was told to change my rear brake pad....I was ???? Cut thing short, was told ideally was 20k must change brake but usually about 20k plus than change for my case. I bought my original pad and sensor for $130 plus in serangoon area if my memory didn't fail me, and get a mechanic change at $60 at sin Ming and reset the rear brake timer. Less than $200 but pml charge $450. That my legal way of cutting cost but my friends said I am cheap skate, can afford bm want to save on servicing...I went !!!!
Bro. Dun bother abt wat ur fren said. Im doing the same as u too. Save $200 for the same thing. So u r $200 richer then ur fren.
