Retrofit F10 with M-Sport suspension
Re: Retrofit F10 with M-Sport suspension
darkknight;655122 said:
Bro, so any mob for our N52? :thinking:
Bro, sad to say no :mad: I even email burgertuning... hahaha... sibei sian...
Wow, u're hard core man!!! :thumbsup:
nvm lah... zing exterior suffice liao... :woottt:
Cannot la bro... Exterior is for others to appreciate... Power is for self satisfaction :thumbsup:
darkknight;655146 said:
Bro, have u lower ur ride? which mode? :shock:
Haven't lower cos still on stock wheels so no point... Talked to Juzz for Cars, if comfort is your priority then stock suspensions are the best option... I will be looking at KW V3 Coilovers when I up the wheels to 19"/20" http://www.bmw-sg.com/forums/uuc-parts-wilman2772/46830-kw-v3-bmw-f10-5-series.html... Lower springs are a cheaper alternative but no comfort lor...
Bro, have u taxi ride on any bro's F10 with only lowered spring? sure no comfort?
No budget for coil over leh... :(
But never lowered... cannot tahan the gap... :angry:
Darknight buy me a kopi and you can take a look at my ride, just joking la. Give me a call and you can take a look.:)
A pic of my ride lowered with spring while waiting for my coil, hope this help.
Give me a call if you want to take a look. Ride is comfort like stock :)
Bro, very nice height!!! Which lowered spring u used? H&R, Eibach or Koni?
porky88;655057 said:
Hi All,
Anyone retrofit their F10 with M-Sport suspension? If not who do I talk to in PML?
The parts department? Or can I call Munich Auto? They should have the same access to parts database yes? Or ideally, is there a modding SA from PML/Munich to talk to?
Coming from an Audi, modding was much simpler... just need to give Quek a call. :)
Sline suspension.. oem big brake kits... MTM stg 3.... those were the days...
I did some digging on realoem.com, spring strut, dampers, springs, stabilizers(roll bar) are different. Should be a very easy job. Unless you have dynamic drive with dynamic dampers, then a bit more complex. If not it's a part for part swap.
Cheers.
Hi!
If you're looking to improve your handling, there's not that huge a difference between stock and M-sport suspension. Coilovers on the other hand will have a more pronounced effect :)
I've tried both on my E90 335i so i'm waiting for my suspension to go and then it's coilovers for me.
Have fun!
SY3;658525 said:
Bro it is h&r.
Thank you so much! :)
Hi All,
Cheers.
M-Sport Suspension is part of the M-Sport Package which has to be factory fitted. So from this perspective, your salesman is right. Customers may additionally specify Adaptive Drive or Adaptive Damper Control instead of M-Sport Suspension (which was what I did).
However, at a later time, BMW usually avails M-Sport Suspension as a stand-alone retrofit offering. Until this happens, you will not see a part number for M-Sport Suspension Retrofit.
If however, you do not mind those disclaimer clauses etc, you can order the individual parts that make up M-Sport Suspension and have them fitted. PML will probably sell you the parts but I'm not sure if they will have them fitted for you as it's not an official offering.
Have fun!
SY3;658525 said:
Bro it is h&r.
Bro, done mine with Eibach!!!
Surprisingly still very comfort... :cloud9:
Will post pics this weekend...
Hi bro
What is the drop for the front and rear , is your 20 inch rim staggers setup ? Worry rear with passenger sitting might kena the fender
Let if know if yours is okie and where did you change your Eibach
Astinal;659579 said:
Hi bro
Bro, drop front 30mm and rear 20mm...
Yes, 20" staggered...
Tested with 3 full size adults at the back... never kena fender... :goodup:
Best! still have comfort...
Will pm u the location... found them by chance while waiting to be served... :shock:
Astinal;659675 said:
thanks bro , awating for your pm,
PM sent, bro!!! :dance:
bring up an old post... since there are much more F10s now...
any interest or updates on m-sport suspension as a kit?
nope i dont see it as a retrofit kit yet
am also interested in the msport susp...
read about kw v3 but am not sure if it's rated correctly for our lighter 2.5L N52. it states the 3.0L N52 as the desired engine. it's heavier... i know can adjust, question is how much.
ae888123itsdone
