Rub or no rub?
Ahbengdriver
Legendary 10 Years
Saw on E90post.com some E92 fellas are using the following offsets, some said rub against fenders, some say no. I guess the ride height affects too.
lets say the car is on OEM sports suspension, will the following offsets rub using 19s?
8.5J front with et 32 (on 235/35/19 tyres)
10.0J rear with et 25 (think this one requires 275/30/19 tyres at the rear)
Re: Rub or no rub?
i thought 235 goes with 265
245 goes with 275?
and 235 should be 9J
Re: Rub or no rub?
245 goes with 275?
No lah. The usual is 8.5J with 235, and 9.5J with 265 mah.
Re: Rub or no rub?
anyway
my 235/265 no rub.....in fact a lot of space left.
kenn's 245/275 rubbed. he did roll;ed his fenders
Re: Rub or no rub?
It depends on ur offset. I'm on 245/275s and its fine too.
I think u should not rub with that kinda offset, ABD.
Re: Rub or no rub?
Sam, what is the offset and width of your wheels for front and rear?
Re: Rub or no rub?
is there any other way? It never depend on rim size. Lotsa people use 10 inch for 265 for example, for more `stretched' effect more swee.
Re: Rub or no rub?
Jadis, Iforged didn't give me offset for my rims but I can estimate the front to be about +35 and rear to be + 22 or so.
Re: Rub or no rub?
I got the wrong info from this:
Wheel Offset Calculator
Now I know the reason why my rear wheel rub after car lowered. Based on the above, I got at least 8mm allowance. If based on your calculation, I have 0mm allowance, that's reason why got rubbing sometimes.
Re: Rub or no rub?
OK heng... this tire bible guy i gave him US$50 bucks because he is such a god. Your practical experience already verify his webbie's accuracy. Cool shit, Jadis.
Re: Rub or no rub?
I am running 8J 235 front and 10J 275 rear. Rubbing with depends on offset - mine rear wheel's +30 to 32 thereabout. Beng, +25 is quite aggro at the rear.......
FYI, for those Procede-ing, rear running 265 rear might not satisfy your grip needs.......
Re: Rub or no rub?
Azrielsc;289145 said:
Ken, even 275 have difficulty in keepin the stock car on the road...
In sport mode, I think you can but you must throttle more progressively, then the rears will hook up. With DSC+T on it is not an issue of course. Increasing the rears to huge size does nothing to help the medium speed understeer issue.
Re: Rub or no rub?
Sam, front +35 is fine, I doubt rear is +22 without rubbing.
Re: Rub or no rub?
no leh, we tried liao mah. 18 tyres(255 rear) also can in DS mode:lol2:
Re: Rub or no rub?
Hahahaha you kiddin me? Ask Omar why he needs to upgrade to 275.........
