Re: Self Intro BMW 335
Powertune Australia
ABN 45 035 010 911
POWERTUNE AUSTRALIA is now the proud authorized dealer for JBT MotorSports
In development & testing since 1994, & on sale to the world since 2002, JBT Brake Systems are manufactured in Taiwan and assembled in Australia. JBT Performance Brake Systems provide the ultimate solution for your automotive braking needs. Utilizing advanced forged technology (the same you’ll find in light weight wheel manufacturing), JBT Performance Brake Systems allow optimum braking and increased performance from your tuned vehicle.
JBT Brake Systems are manufactured to the highest levels of quality. Our Brake Systems are competition-ready out of the box and have been given the ISO9000 (International Quality Standard) and TUV seal of approval. ISO9000 & TUV approval (to European Standards) represent a far more stringent testing program which exceeds the requirements set by local standards organisations. Consequently these product are recognized as ADR, AS & NZS compliant.
We use superior quality materials in the construction of our brake componentry. We utilize aerospace grade alloys & other high grade metals to manufacture leading edge brake products of world class design. JBT Brake System brake kits not only provide your car with that ultra-high performance look and feel, it also exceeds your stock performance calipers in a number of key areas including improved heat dissipation, far shorter braking distance, better brake modulation with firmer brake pedal feel and most importantly, the elimination of brake fade under spirited circuit driving situations. Furthermore, the JBT front and rear big Brake Systems have been specially designed to work in unison with your factory-installed ABS to offer balanced overall torque ratio distribution to maximize the traction capabilities of both the front and rear wheels.
With a range of mono-block construction calipers and ceramic coated & full ceramic rotors in the pipeline, JBT is committed to the on-going improvement and excellence of our products.
JBT Brakes has been around for a while and we now carry them as an exclusive distributor in Australia. JBT brake setups have been used on many street cars as well as in numerous racecar applications. Whether you are looking for a shorter stopping distance, increase brake pedal sensitivity or improved looks, JBT has you covered.
With a very attractive price proposition and a big brake kit available for just about any Australian, Japanese, Korean, American and European model on our roads, the JBT Brake System is the preferred upgrade for discerning drivers world-wide. JBT Brake Systems are now sold into Australasia, US, UK, Europe, Japan, Singapore, Thailand, Russia, Middle East, and many other regions throughout the world. It is also a popular choice with motorsport competitors around the globe.
The choice is simple, for quality, performance and value for money, there is no formidable alternative. Nothing comes close to JBT. Gets yours today!
FOR FURTHER INFO ON OUR AWE-INSPIRING BRAKE SYSTEM, READ ON.
Caliper Features:
> Constructed from Cast or Forged aerospace grade aluminum alloy (6061 grade T6).
> Titanium alloy pistons configured in a staggered design, provides for better pedal feel and reduced pad taper and wear. This also provides progressively consistent braking in even the most extreme braking situation.
> Carbon steel adaptors for maximum strength and heightened safety.
> Stainless steel mounting studs.
Disc Rotor Features:
> 2 piece construction. Rotors with floating assembly.
> 7075 T6 Machined bell ( Hats ).
> Cross-drilled or slotted, directional curved vein ventilated rotors for maximum heat dissipation.
> Anti-corrosion zinc coating to prevent corrosion.
JBT Stainless steel braided brake lines:
> DOT Certified.
> Abrasion-resistant Teflon plastic coating for added protection.
> OEM bracket for factory mounting location.
> Quicker pedal response.
Brake Pads:
> High Performance street compound suited for all round performance road use.
Fabian Coulthard Joins JBT Brake Systems
JBT Motorsport Australasia is proud to officially announce an exciting new partnership with V8 Supercar driver Fabian Coulthard. This relationship will see Fabian act as an ambassador for JBT Performance Brake Systems
Read this article in full...CLICK HERE
Silvia S13, S14, S15
Skyline R32, R33, R34
Front 6 piston caliper with 355mm slotted disc rotor = $3600
Rear 4 piston Caliper with 330mm slotted disc rotor = $2390
Calipers come in a range of different colours
Red, Black, Silver Painting and Chrome Polish ( Chrome Polish is only available in forged caliper )
Calipers also come in a range of different sizes ranging from 4 piston all the way threw to 12 piston
which means we can do a brake kit for any sort of application
Disc Rotors come in a range of different sizes in slotted and X-Drilled
sizes range from Ø282, 302, 330, 355 and 380
Please note all kits are complete & include:
2pce floating 40 curved vein rotor assemblies with forged T7 bells
T6 cast callipers with Titanium alloy pistons(forged option available)
Hi carbon alloy calliper mounts(light & super strong)
Braided stainless hoses & ceramic/carbon metallic street pad(temp 0-650deg c)
Street Pad tolerance:0~650℃
Race pad( 50-850deg c).(optional upgrade for $200)
As you can see JBT BRAKES are a no nonsense HI-PERFORMANCE product, we will not compromise quality for price, & we will not supply a brake package that we believe to be unbalanced.
if u would like a custom kit put kit put together it can be arranged
POWERTUNE now offer a big range of upgrade brake kits for all makes and models so if u would like a price on a different make and model let me know
