Re: Sign up for BMWSG Sepang Track Day 4 Feb 2012
hahah yah.. just remember who taught you that.
The additional drag at a big track like SIC may be enough to offset those advantages though. Also more apparent with hard top convertibles vs softs.
Thing is.. Lap to lap the 105-180 window was can be 13.8 up vs 13.8 down, or as far apart as 13.6 down vs 14.0 up. So actually faster in a straight line with top down. Possibilities:
1) There's lots of flow separation with the top up, to the point where dropping the top doesn't increase drag. This is highly unlikely and can be coastdown tested.
2) Dropping the top actually reduces drag. Even less likely and coastdown results can tell.
3) Variance from other factors; mainly water, oil, air temperatures and the ECU compensations for it affect power so there's no trend in up vs down because a proper test (ABAB) same stint, strict process, was not conducted.
Separately, top down is less safe in a rollover though... arms can get thrown outside of car unless you wear arm restraints. Upper body too. Hardtops probably are able to support a meaningful amount of load.
Elite;746424 said:Lol ... Took the other car -- now there's a legit reason to go tracking topless -- lower CG, better weight distribution![]()
