Signs of "Eating" Engine Oil.........
Ninja
Other than white smoke, what other symptoms are noticeable from our E90 06 model
No white smoke from my ride, other than morning cool weather. 4K top up 1.5 litres.
Can it be valve seal issue, other than that, what other possibilities can it be?
Any similar case ?
Need advise
Re: Signs of "Eating" Engine Oil.........
Any similar case ?
Need advise
Assuming u don't have other parts leaking engine oil
Please do this simple test:
Start engine for 10 mins,
Rev hard one time
U should see obvious white smoke.
Valve seals worn off.
This is just a simple test to guess the problem.
End of the day, u still need to go workshop and have it inspected.
Thanks Aaron, will try tmr
Rev hard one time
before this tail pipe already black black lei
F30BKSP;1087310 said:
Tail pipe black black.
Aaron,
tried your method, yes white smoke seen, after 10mins of idling followed by WOT.
more or less confirmed.....
Ninja;1087436 said:
Aaron,
Ya.... Follow my thread.
Change the valve seal.
It will solve the problem
Nowsday can change valve seal without opening the head... Cost is cheaper
How do u do that?
There is special tool required. Cost in JB around rm1300 inclusive of valve seal
Cool. Please PM me the details
Is it done at your workshop ?
You can do gearbox also ?
Hey Jackie, can PM me the WS contact please.
j88events
