Simota Full Carbon Fiber Air-Box E90 non-lci only
sperry
Condition: Like new, never used. Test-fitted only
This will not fit 09-onwards model
$850
Re: Simota Full Carbon Fiber Air-Box E90 non-lci only
U might wanna revise your selling price. Local wkshop selling less than 1k. FYI.
ic.. thanks for the info
What is this for? 320? 323? 325?
will my car my be louder after installing this ? or just for beauty only ?
i adry have r2d airscoop ....and my exhaust is decently loud ...
the plus point is the air snorkel is opened up 2-ways for air scoop.
for oem, 1 side is blocked. existing e90 320 scoop owner may want to add 1 more scoop :D
in term of noise should be similar to k&n,bmc,hurricane drop in. i'm told that there is a loss of low end torque (abit)
check the quality of the CF. i have seen at least 2 sets crack (hairline and some serious)
[ame]http://www.youtube.com/watch?v=8EBf3xvprME[/ame]
YouTube - ‪Simota @ 3er E90 320i‬‎
sounds more raw than with K&N. i moved from K&N to this.
loss of low end torque confirm also. :(
Just add velocity to counter this low end problem.. haa quite true car become a little sluggish during low end. need to rev up a little.
somehow it just don't fit.
another example, gruppem for 320 pfl. the form factor and package looks 99% identical but it just don't fit into 320 lci. there are 2 parts no for pfl and lci 320.
pengful;565405 said:
If this is true, why would it not fit 09-onwards models?
unichipped and velocitied. still can feel sometimes. bo pian. 320 nia. :sickinbe:
check ur pm
this is as close as it gets to the best closed system already. Open-pod will be too loud and crass and lose alot alot of low-end torque
the stock air-box scoop looks huge but if u inspect underneath actually the scoop is one side on, for eg. only taking in air from one kidney grill. Changing to the simota will mean taking in air from both kidney grill. the surface area of the air filter inside is also almost twice that of the stock. All the above reasons is why i got this system but unfortunately does not fit my lci
It's not suitable for 6-cyl models? Any idea where to get them instead?
BombaBahis
