Smoke coming out of exhaust when car is stationary.... is it normal ??
ipoh-horfun
Need some advice.
Smoke coming out of exhaust when car is stationary.... is it normal ?? smoke is rather heavy.
last time rem had this issue.... it was back in winter months in australia
driving F10 523i
Re: Smoke coming out of exhaust when car is stationary.... is it normal ??
it's normal in the morning
Smoke coming from the tailpipe is not good news, but does not necessarily mean the engine needs rebuilding. First, you need to determine what color of smoke is coming from the tailpipe. The three most common colors of smoke that can be emitted from the engine and billow from the tailpipe are as follows:
White smoke: White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area. The cylinder is where the fuel and air mixture are being compressed and burned. Any amount of antifreeze that enters this area will produce a white steam that will be present at the tailpipe area.
If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the under side of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze, as serious internal engine damage can result.
How did antifreeze get in the oil or cylinder in the first place? The engine probably overheated and a head gasket failed due to excessive heat, thus allowing antifreeze to enter the cylinder (Where it is not meant to be).
Blue Smoke: Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Black Smoke: Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor. How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil as in the white smoke example to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil. Call your mechanic and advise him of what you have found.
nb wall of text...
in short
white smoke ok
black smoke not so bad
blue smoke is hong kan
I learnt this from Kenn..
I meant grandmother stories..
mine not blue or black..... just usually smoke like Winter times..... but was raining last evening la..... then car behind me lights shine on my ass... making the smoke look obvious....
its very normal la mai worry
they time call back 5 series... i thot i kena EWI...
under warranty why worry but u gotta worry if dealing with pml :p
Your car is about to explode. Faster sell off
bro to bro price lai :D
must be long time never post in NSFW folder.... its a sign that your taiwan mei mei have gone cold....
jason u talking about yourself i still waiting for that part 2 of your youtube vids that shows raisins u da man
smoke is normal so long it is not very thick and dark type
Mine F10 morning if after rain will have white smoke too... after a while ok...
Horfun, the smell of the exhaust smoke is also important.. Not only colour.
morning means at what time???
cheerssssssssssssssssssssssssssssssssssssssssss
does your car fart when u fart?
bro.. morning around 8 plus when i start the car.. sometimes got white smoke especially when after rain... normal?
vip777orgph
