Snake Oil Product for E92 335?
kenntona
Legendary 10 Years
Came across this on the web. Sounds too good for the bhp/torque gains?
eBay Motors: Eurobahn Turbo Tuner for BMW 335i E90/E92-Free shipping (item 270132288550 end time Jun-24-07 10:44:34 PDT)
"I did a 1/8 mile in 8.425 @ 84.33 mph. my 60' time was 1.934 with runflats and my r/t was .560 this was with 91 octane my best time before the turbo tuner was 8.733 @ 81.08 with 93 octane"
"Before the turbo tuner my best 0-60mph stock was 4.9seconds.. with the turbo tuner my 0-60mph time is now 4.52 with steptronic"
Sounds to me like some snake oil? Any comment?
Re: Snake Oil Product for E92 335?
Don't know about the what it does for the car Ken.. but wouldn't your pet snake benefit somewhat??......:) :uhhh: :oops:
It is supposed to give comparable performance to the procede version 1.0 according to dyno made by users in e90post. Supposed to go for usd500 only. Was considering this cos it was install to easy to remove.
Given the cost, not much of a downside...one of u guys should give it a go and post your own review here.
Ken, unless you know someone who has used this product before I wouldn't touch it...
There are actually quite a few people using it in the US with no issues...and it is easy to install and remove (compared to the PROcede)....but most people have gone with the PROcede...you should get the PROcede....won't regret it esp. when V2.0 comes out
Ken
BIAN lah! On 91 Octane, already 4.9 leh!!!!
When we already use 98 Octane here.....then what? 4.85 ah?
Anyway, are the specs different in the US for the 335? And also given the very different environmental conditions like Air Temp, humidity and so on versus our weather, things may be very different too.
Anyway, my point is.....the freakin' car is already a 5.6s car, if I were to put in $$$ for the car, it would be an LSD......after that....SWEE SWEE liao.....And I was also told by Pak TripleM that the step shift is DAMN Quick lor!
Haiz........me can only dream dream dream of owning a 335i.......
Simon, u can Procede the E92 335i and it'll be a 4.8-4.9sec car too. Combine that with a LSD and u have a pretty fun car!
What about a E90 335i @ S$208k, Simon? ;)
Is that after 7pct GST Sam? kekekeke
Another version. This one costs US$1100 !!!
eBay Motors: AA Tuning XEDE piggyback for BMW 335i E90/E92 (item 250133190633 end time Jun-28-07 12:34:03 PDT)
Active Autowerke tuned XEDE Processor is a state of the art programmable engine interceptor computer that is designed to work in tandem with the vehicle’s factory ECU.
The Active Autowerke XEDE Processor generate changes in fuel and ignition by commanding the factory ECU’s load and crank reference input signals to deliver increased power and torque, optimal throttle response, improved fuel economy and smoother acceleration.
By working through a collaborative effort with Chip Torque, Active is able to upload the Xede processor through a proprietary firmware with specific Active Autowerke tuning files. Noticeable performance can be measured when the boost ramps up to 14 psi which is a nice gain over the stock 8 psi. This just goes to show how well a balanced turbocharged motor can respond favorably to a gentle bit of woosh...
In conjunction with the original BMW computer, the extensive development that BMW has incorporated into dynamic tuning and “limp home” strategies are all still maintained when using the Active Autowerke XEDE Processor. This ensures reliable driving at all times to this new performance edition in the BMW range.
  • Proven additional HP and Torque gains measured on the rear wheels
  • Verified and tested on Active's own 335i and other 335is in both manual and steptronic transmission cars
  • Xede unit is small, compact and is easily attached to the factory wiring harness by a competent technician
  • Full control over the Fuel, Boost parameters and Ignition
  • System is fully reversible and leaves no trace
  • The unit can be programmable for later revision upgrades and can be easily transferable to other 335i
  • Support and tech assistance by Active Auotwerke​
This device alone can give your 335i UP TO an additional 45hp and 80ft.lbs torque! (Results will vary)​
ok , at least it's better branding...
but then it leads to doubling the price
The amount of work to install the XEDE is the same as installing the PROCEDE. Vishnu started off using the XEDE then switched to PROCEDE. The PROCEDE supposed to have more inputs including extra digital ones compared to the XEDE which supposed to be used in version 2.0.
There's also no clear indication of how to update the maps on the AA XEDE right now, but PROCEDE have been releasing new maps since 1.0, and current is 1.45.
If you have to pay USD1100, think better off paying extra USD200 for the PROCEDE i feel.
Xede is the forerunner of procede. Think if the Xede as version 1, Procede as version 1.5 and the upcoming Procede as version 2.0.
Ask Omar to come in, he's been researching a hell of a lot more on this than me :) But chuck the xede, go with procede!
Chew has just been nominated the mod-moderator of E92 335......
Now easily sub-5 seconds. Even TripleM is selling his M3.........
That's because I need moolah lah..
I m still up for a drag challenge if any of you has already chipped up your 335
CyberTron;218306 said:
nar...I pass. I've the most stock E92 :)
Bro one day I drop by your place see your stock car can anot?
