So u think u can Volk ME?
Re: So u think u can Volk ME?
M5port said:
I was thinking to fit that on my E60 , but then there no lip =(
Yeah, think for big cars in general will look nicer with deep dish design.
Took one shot today during my photoshoot with HS :)
well maintained as usual. awesome!
better airbrush your number out or you might receive a fine from cisco/URA. sign behind says "no parking"... hur hur hur
Hi there,
can these rims fit E90 325i?
am looking for rims that will sit flush with the fenders
Yes. it will, evokim.
if you like Volk Progressiv ME
the spec recommended by RAYS for E90
front Face 1 19x8.5 ET35 235/35
rear Face 2 19x9.5 ET30 265/30 or 275/30(if you like more higher sidewall)
if you like more aggressive for the rear, you can try ET22 for the rear. that's what TrippleM using for his rear.
good luck.
good luck.
how difficult is it to fit ET22 at the rear? can just by rolling fenders can rectify it? or you need to put on aggresive camber as well?
how about E92... from what i know...E92 is running even less agressive offset
For ET+22 at the back on new 3 series..
I think E92 can take it with aggressive fender rolling plus -2deg camber 275 tires..
Seems to me that E90 offset is slightly less aggressive than the E92 so
I think max E90 can take is +25 with rolling and -1.5 deg camber 275 tires max
If u do +30 at the back, no rolling , no rubbing , even with 275 tires n quite flushed
Jack and Acupunch,
is +30 for the front flushed? or we can go more aggressive?
errr... from what I learned so far, most 8.5 width wheels on the front of E90 max can only go ET+32. anything more aggressive will rub when lower the car. for my front its 8.5 ET+35. for the rear, I know TomTing its on BBS RGT 19'x9.5 ET25, flush tight with KWV2. rub or not, u better PM him to ask.
generally, 8.5 width ET35 for front and 9.5 width ET30 for rear its very safe lo. lower kow kow also clear fender pretty nicely. its all depend how much sacrifices you willing to accept, in the US, ppl even take out the sound protector on the rear wheel arch to lower the car to get that slammed look.
COMO: you're changing to what wheels?
anything its possible, and nothing its wrong. as long as you can accept. e.g. yourself can fit on 3-series //M offsets on a 5-series knowing its not optimum but u take it that it can be compromise by adding spacer to achieve what you want.
i've learned from Jack and others, it is good to choose an offsets that its optimum/recommended for your car. its more towards bolt and go type or plug & play lo. E90 & E92 should be similar, most difference its +2 or +3 for front and rear.
thanks for ur write up.....
i am intenting, light weight....but have not look at in depth.....most prob volks.... :)
no write la.. jus some simple facts that can be found everywher. since its talking abt ME it makes it easier too. others u'll need to talk to Jack the wheels GURU.
what you had in mind? you like deep dish?
preferably deep dish............is 19 on ur car makes the car sluggish?
i drive a e90 with 19 inch...feel it is damn sluggish......
sluggish or not, i'm not sure, cos never really driving with stock for long enuff to tell. got myself upgrade from 16" to 18" the nxt hour I drove out of PML. anyway i never expect any pulling factor to come from a stock 320i. all i know its if i want power, I'll go DS or even drop 1 shift to get the rev I want. i'll be in pretty good hand if I'm on 3500rpm and above, the drives its smooth.
I think going into large wheel size, the build, weight and strength its important factor to concern. even recently tires materials and weight plays a big part of the set up.
what 19" using currently?
COMO
For E90...I think it's possible to max it out there and dial ard -2deg camber.
And when u want to combine the front +30 with the rear, I strongly suggest you get +25 or +27 for the rear ( 9.5J for eg ), and roll your fenders..
Shud be super flushed and handling is good too as u hv wider front track.
Normally the rule of thumb is this..from factory set ups, u can go up to betwen 5-7mm +/- in terms of offsets depending on your preference and of course, fittability.
And we know tht factory set ups on BMWs are always on the conservative side.
If u take example of the Volk ME for E90 fitment, +35 / +30 8.5/9.5 are fantastic...perfect I should say. U can comfortably slap on 245 / 275 tires w/o worrying bout rubbing even ur car is lowered.
u shud meet with acupunch and check it out urself.
Thanks Jack and Acupunch...
I saw his car, swee swee manz.....
very high chance....it will be a JDM rims....:)
It is a nice blend.....ang mor father + jap mother = chio kids...hehe
mine alot of people say not chio.... its the german father fault or japanese mother fault ? :(
aiya terry, you better get the deep dish back...
first, the wheel color does not match your car, Mercury Silver maybe?
second, the offset is not aggressive and thus no lip at the back, look not right...kind'a funny
third, the design is too common as seen on many Oriental makes...
COMO, if you like I can taxi you on my car see if you think its sluggish.
pg88comim
