SOMEONE RESCUE ME ! smoke
pike_account
has anyone encounter same problem as mine??
there are some little smoke came out from the engine (driver side) extactor just beside the steering shaft.. no rain nor water went in at that moment..
As 1month ago just change casket. As i self check inside odometer show ~ all car check is ok.
Expert please advise whats the problem is. ..
please thank you!! MUCH MUCH..
regards..
pike
Re: SOMEONE RESCUE ME ! smoke
3 possible leaks.
1. Engine oil leaking from engine cover gasket.
2. Engine oil leaking from vacuum pump
3. Coolant leaking from back of cylinder head
all these 3 areas leak from the back of the cylinder head driver side and drips onto catalytic converter. smoke usually happens after about 4mins of driving in the morning right?
so what should i do now?
normally how much does it cost for repairing?
i check the radiator water is full so should be ok right.
As little smoke keep coming out from extactor side..
can provide me some guideline costing?? thks u
model: BMW 320i (E90) 2006
regards
pike
ask shaun. prob need to dyno at subaru. independent witnesses needed. 3 hour apart is too long tho...
regards
pike
Juz drive it into a workshop & get it fixed. No point in guessing with the problem.
1 dark saturday, my pwr steering become powerless & got smoke from front left engine bay. I thought pwr steering pump uplorry. 1 hr later, workshop told me water pump up lorry & snap rubber belt.
hi, buddy!
i bought the extended Warranty from TWN... but i dont know is it covered a not. as least see anyone kind enough tel me the nearest problem rather than kanna carrot by workshop mah.
this is the 1st time i own BMW for only 3weeks so suay... lastime i drive honda, very straight forward car if have trouble, very easy to know where the problem comes from.
but BMW is more high tech cars.. im not really familier with.. needed to learn more in case nextime have trouble i know how to handle with.
regards, ..
pike
BMW is a journey.
It is not THE destination.
If kena carrot, it is part of the journey.
That's what a forum is for - share information...........Let us know if warranty is covered.
pike_account;637667 said:
hi, buddy!
regards, ..
pike
Hi, is your problem solve? I just saw my car having smoke coming out also? Can advice whr and what been solve pls?
sszone;721263 said:
Why don't u give Rodney of r2d a call?
ya, already given, as my car used to service by him. sending over to him soon. he suspect oil leak to exhaust manifold that why got smoke when hot.
shbetlegal
