i afraid that is no 10mm for your case.oldschool;598628 said:looking at 10mm probably.. where can i get those..?
Brother Gadaffi, why is it dont used spacer for rear wheel drive?gadaffi;598669 said:you can try local tyre shop (reputable on). They can customise for your dimension. IMO, dont use spacer for rear tyre if ur drive is rear wheel drive. What kenn say is true, if they can supply long bolts then its ok but do ask for extra, just in case of emergency.
roberttan;598715 said:Brother Gadaffi, why is it dont used spacer for rear wheel drive?
my undersatanding is most spacer are for rear wheel drive.
Customised spacer is OK but most reliable one is still those branded one which has lab tested.
customised spacer you have to beware of some poor designed and material used.
mounting bolts lenght is the job of the shop whose sell and install that make sure is correct spec.
as this quote.kenntona;598621 said:If hubcentric, if not too thick, if bolts are long enuff to secure the wheels on spacers, then the answer is no.
theoretically if the spacer thickness of 15mm it will change of wheel offset (push out) by 15mm (do remember our car may be left /right not 100% same distance)tomace;598798 said:Hi & sorry to OT..
Since its on spacer, May I know which size to go for if I would like to push out my stock 18'' M rims? Im driving an E90 320 m sport.
Thanks in advance.
roberttan;599171 said:theoretically if the spacer thickness of 15mm it will change of wheel offset (push out) by 15mm (do remember our car may be left /right not 100% same distance)
example your wheel offet 20mm after the 15mm spacer it will became 5mm.
SO my advice to you is get the advice from the shop seller and with installation,
BUying cash and carry you are also carrying a risk of wrong specification.
and all automotive item are sold non returnable once installed and used.
From my understandingmyst17;616033 said:Hi all,
Noob qn..what is a spacer and what does it do?:thinking:
Thanks in advance for all bros who take the trouble to explain.
gadaffi;598729 said:it is just me as i dont feel safe with it bro.
