Spark Plugs
Re: Spark Plugs
yendor said:
Shaun
Taking a leaf from the hot cold plugs thread, I think that the intense spark maybe one of the reasons for producing better power. On one of my previous rides, I installed a Bosch sports coil (distributor type of setup) and there was a notable difference in the car's performance.
If there is misfiring in the engine then a more intense spark may help the burn start up in a more stable manner. Misfiring just like detonation is not always detectable by human feel or hearing - so though the base engine may appear to be running fine and then after the ignition hop up may yield power giving the impression of a power gain, when in fact it is a recovered loss.
Is there some mathematical relationship between spark intensity and rate of burn?
There is no relationship between spark intensity and speed of flame propagation. Let me put it this way.. Taylor, Blair, Heywood, Lumley... none of them ever mention anything remotely related to spark intensity affecting burn rate. What they do mention as factors to burn speed are all the usual - AFR, charge turbulence as directly related to engine speed, cylinder geometry and chamber design. All they say about ignition is that it is a start to the burn.
There is a relationship between spark intensity and when the flame propagation begins, IF the original spark wasn't intense enough to carry out the job it was supposed to be doing in the first place. If the original spark was doing its job, then the difference between normal plug and fancy plug ranges in mere us-time / fraction of a degree, as mentioned.
So in this case i suppose that with lower ionisation voltages, the coil is able to generate a more intense spark that leads to faster combustion.
It potentially leads to earlier start of combustion, not that combustion is any faster.
Any time you make combustion significantly faster, you experience big gains in power because more of the force can be applied closer to the optimal crank angle. This is not what's happening, no matter how intense the spark is. To maximize gains, on top of the shorter combustion event, you need to shift ignition again to re-center 50% mass fraction burn over the optimal point, yielding best torque.
The only way to verify this is to plot the ignition signal with the cyl peak pressure time. In the case of non-invasive pressure measurements, this is impossible. Any ideas?
Kistler makes some offert sparkplug adapters that allow you to fit the sensor next to the sparkplug. Maybe you can get those?
Do you have access to an engine with cylinder pressure measurements?
We don't have a intruded mule engine on which we test plugs or other individual components. We have an engine cycle analyzer that is specifically designed to work with our SF-902 engine dyno as well as the older 901. It references crank angle to non-intrusive sensor-on-plug system. It is not a system that allows you to use other plugs, so I don't think it can be of help in the tests you seek to conduct.
In any case we don't use it much at all because of all the distortion of even the finest components in both the lower and upper assembly at near 5 digit RPMs and 32m/s mean piston speeds. The harmonics are crazy and piston position is never really known esp the furthere away from the crank snout you get. Charging variances between cylinders also starts to occur because of the valvetrain distortion with even the cam core twisting!
Dyno cell time is also at a premium with all the stuff going on daily. Would need a fairly substantial project to squeeze something like this in on.
Re: Spark Plugs
TripleM said:
Rod
I make good sales person, don't I ? kekekeke...
u write concise and comprehensible FR, dats why layman like us can understand u and hv confidence in the product...
Re: Spark Plugs
Thanks dude.....now, wots stopping ya? :lol2:
Re: Spark Plugs
No stock lah. Damn..should have installed it the same day as you did. :furious:
Re: Spark Plugs
TripleM said:
Rod
Thanks Jack, really blown by your report.
BTW, you've got PM...
Re: Spark Plugs
Guys and Gals, I have started an ordering list in the bazaar thread to gauge the demand for the plugs and the various heat ranges required. Cheng poh would like to guesstimate the plugs to order so that maximum cars can benefit.
Please fill in your needs in that thread.
Thanks
Rod
Re: Spark Plugs
Thanks
Rod
I'm in liao!!!
Will call you when I touch down from hong kong on friday to discuss about the heat range tingy....
Thks bro!!
'The Great White'
Re: Spark Plugs
Thanks Rodney for installing the plugs today.
Heres my feedback using the Spec II 8VR plugs.
Lighter throttle at low rev, now eliminates my 1st gear clutch bite shudder.
Went for test drive (4ppl in the car), car pulls but cant tell if there is any gains from the plugs.
After meetup, went for dinner and during the journey, cant feel that it has much gains like the 7ZX plugs. Only slightly better than stock plugs.
After dinner, half way back to home. The car feels different. The pull is so much stronger and smooth, very very eager to move. Even my GF also felt it. Its even better than the 7ZX!
Somehow, the above happenings could be due to ECU learning process and eventually felt the power. Think the ignition timing also automatically advance.
Hope tomorrow it can be faster still. Hehehe
Thanx Cheng Poh and Rodney.
Re: Spark Plugs
You getting a little naughty right foot right?...Ha..ha
Re: Spark Plugs
Huh? got sound changes meh???
Whisky_Tango said:
No... well behaved, still brake to slow down.
Oh yah this plugs are more stable, can feel the engine vibrations and sound changes too.
Re: Spark Plugs
Whisky_Tango said:
The sound is more compact. Like more tight and not scatter about kind.
Certainly more torquey now.
Oh shit now i think i want to get CP to get me some of these plugs too...
Let me know the outcome...
Re: Spark Plugs
Yep Eric
Monitor the adaptation for a few more runs then u will get a better conclusive feedback..swee2x..
Re: Spark Plugs
Thanks for the plugs and installation Rod. The car feels more free revving, smooother and eager to go. Will monitor it for a litle while longer to see how it goes. In the meantime, I'm very happy with it.
And BTW nice meeting you bro.
Cheers.
Re: Spark Plugs
Ha ha...
Knew you would like them. Nice meeting you too. Not very often i get to meet another Rodney.
Re: Spark Plugs
Thanks Yendor,
Now I have betta throttle response, that kind of feeling when the UUC pulley was first installed or when one gets new engine oil. Rev climb is easier and smoother. No regrets for me. Kum xia.
ok365ok365com
