Squeaky Sound from Steering Wheel
therock610
Recently discover squeaky sound when I steer right, is like some tension...the sound seems coming from front passenger dashboard, any bro experience this? Btw my ride is E90 320i
Re: Squeaky Sound from Steering Wheel
steering rack..............( likely )
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
MUNICH spray lubrication but still got sound ... will get outside workshop to confirm and then I go back and bang table ...
always have to run 2-3 times ....
One shot will give a long list to BMW asia and german ...
if under warranty just get it replaced.........( i got mine replaced....under warranty )
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
therock610;1018799 said:
Bro ac323, any idea on the damage? Thks
steering rack not cheap.................
* go workshop have a check first to confirm
ac323;1019076 said:
if under warranty just get it replaced.........( i got mine replace....under warranty )
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
ISSUE is they always say ohhh ... lubricate can ... this can ...
then it dun solve the problem ...
then waste our time to keep sending our car in ...
true at times.......so am lucky then
Set rat trap...
bait with cheese...
Yes, i am having the same problem and mechanic said it is
steering rack up lorry.. Costs ard 4K plus.. Anyone can
advise what can i do to solve this properly without changing
this steering rack ? Or Malaysia workshop can solve this
problem cheaper ?
Appreciate all bros to help on this urgent as car is in
workshop now awaiting changing..
my number 9seven333sevenseven5..
problem cheaper ?
bro maybe you wanna call Eng Soon 62917775 to check the steering rack price & + labour from your workshop to see whether can save a bit or not...
Send my car to check today, found right side suspension front mount crack, replaced, sound gone...
I think you just need to adjust the elevation of your steering wheel, upwards or downwards.
Try that bro, not due to that but the WS also mentioned without changing the mounting, they can't confirm is the steering rack, still monitoring
Most likely steering rack cupping wears off. (see attached link whole item 2 section)
RealOEM.com BMW E90N 320i STEER.COL.-LOWER JOINT ASSY
Mine was replaced under warranty.
@ Supan, no choice they (PML or MA) have a stupid systems which will do A then B then C etc etc until it reaches R = replace! :)
I believe & assume that mine is still their top record of replacement & trips visited.. lolz :)
Cheers ~~~~~~~~~~~ :)
99okmeme
