axl;168266 said:Yup... I enjoy this kinda thread. Especially when it enables me to (hopefully!) close the gap on track with the Spec C...
Right. For absolute optimum acceleration plot the torque at the driven wheels vs road speed for each gear ratio and use the curves to determine the best exact RPM to change gears.Shaun;168252 said:If you shift at peak torque or a little after peak torque to try and maximize area under the torque curve, then you end up with highest average crank torque, but when you factor in the gear ratios, your average wheel torque is lower (based on average petrol engine torque/power curves and average gearing gaps) so acceleration is not optimized.
If you shift beyond peak power or at redline in situations where peak power is close to redline, or where power does not fall sharply off beyond peak power, then you maximize area under the power curve and you have the highest average wheel torque. Acceleration is optimized.
You can work the shift points by power based or force based calculations and both in the end are the same, just mathematically different. You can also do it graphically by looking at power curves and knowing gearing gaps, maximize area under the power curve. The general rule though, and almost without exception with modern petrol otto cycle engines, is to shift at redline to maximize acceleration. This is just due to the shape of the curves and the gearing gaps.
CVT requires different strategy but we can leave that out since the system isn't perfected yet and not widely used, and also because the electronics do all the ratio changing automatically and the driver is no longer involved in shifting.
This is true, but often the ideal shift point is past redline. Often we run into redline before we would like to shift, and longevity taking precedence, we are forced to shift at redline.
It's not a myth, in fact it is almost a rule with modern petrol engines - especially so with sportier engines.
There are very few modern exceptions to this rule. For every 1 example to the contrary that is found, another 10 can be found in support of it. Pick any production car, with dyno chart, whose gear ratios are published, and it can be shown mathematically.
This has little to do with hp and torque and much more to do with mass, speed, frontal area, chassis strength.
Unless the torque fall off is very sharp, there is no reason to shift early. If it is unclear, it is easy enough to calculate the shift point.
What's important is the shape of the curves. It doesn't matter as much what the actual value is talking strictly in terms of determining shift points. As long as the curves are proportional and accurate, it doesn't matter if they are translated up or down along the Y axis.
Disagree. If you're doing force based calculation then you have to look not only at resulting crank torque after shift, but consider the new gear ratio you're now in as well to arrive at wheel torque.
It is very common not even to see peak torque RPM on an engine driven for performance - especially racing engines. And racing engines are engines that generally have torque peak closer to power peak, which underlines the point about how maximizing area under the power curve and shifting at redline is as close to a rule as you'll get to in shift point selection, and not shifting at peak torque, or shortly after peak torque.
I think it is easier to work a real example than to get lost in the fog. I'm sure you'll find most cars favour shifting at redline. Pick a production car that has lots of data published on it and crunch your numbers.... you'll see..
goggomobil;168664 said:For optimisation of acceleration in the real world, don't have to be so anal, depend on butt feel and experience with your vehicle to know when to shift.
Detonation zones in race engines are in the bottom 50-60% of the engine speed range. High 5 digit engine speeds and higher RPM race engines, this percentage shrinks to the bottom 20-30%. All these ranges are below peak power, so the upper areas cannot be defined as a detonation zone.racing engines where power continues to rise well into the detonation zone
As you continue to shift at redline in the upper 2 or 3 gears, you will find that the operating range is moved away from peak torque because the gearing gaps get narrower (as they always do as gear number rises).for a "sporty" normally aspirated engine (say M54) where torque curve is pretty flat and power doesn't drop off until close to or at the rev limiter, then change gear just before the limiter cuts in and you will find yourself in a fat part of the torque curve anyway (if the designer has done his job revs will not be too far off max torque).
Shaun;168252 said:The general rule though, and almost without exception with modern petrol otto cycle engines, is to shift at redline to maximize acceleration. This is just due to the shape of the curves and the gearing gaps.
Shaun;168825 said:I don't think there's anything anal about spending 10 minutes to figure it out once and then sticking to it in in the future.
Shaun;168825 said:Human feel is not sensitive enough, so the chances of repeatedly shifting wrong while thinking you're doing it right, are high. Quick quantification beats long and wrong intuition.
goggomobil;169152 said:An over generalisation, there are still many engines around that are have rather agricultural characteristics,
No driver-controlled shifting (street or race) in thie world is to the nearest RPM. The human and the tach don't work to the last RPM. You are setting your own unreasonable definition of data application and then calling it anal. Using human feel you miss by far more than single digits, more like triple digit engine speeds at least. Your references to peak torque and fat torque, etc. .....these points relative to peak power, redline are 4 digit engine speeds apart. So when I suggest you do the math and find out, I mean more precision than you inaccurate feel, and your inaccurate theory about shifting to land at peak torque or near it. All this is missing by hundreds and thousands of RPM, which can be easily cut down.Now to truly optimise acceleration supose we spend the 10 minutes to work out the actual revs we should shift at in each gear (to the nearest rpm, since we are being rigorous) and we find that the best rpm to shift in each gear varies because torque curves are not absolutely flat and gear ratio spacing varies. Now what? We don't shift at redline any more but try to shift at the optimum revs for each gearchange (which will be close to the redline anyway by earlier arguments) let's say 6862rpm, 6927rpm etc etc. How close to these exact revs can we achieve, how accurately can we even read the tacho to do this? This is going beyond the point where it is practically useful, and therefore an_l.
You are making assumptions again. It has been found that the human body is poor at sensing speed and acceleration (second derivative). It is really only is sensitive to jerk (3rd derivative) . People involved in production car ride and handling, or race driver development know this.Don't underestimate human feel.
"the chances of repeatedly shifting wrong while thinking you're doing it right, are high". Hey!!!! don't underestimate us humans. Let's put Schummi in a car and don't tell him the optimum shift revs, let him drive around for a while, bet he works them out and gets real close pretty quick. Bet he even does it without a rev counter.
See para 1OK extreme example but we all have the capability to learn (learning not the same as intuition), we are not Schummis but we will get pretty close to optimum for the vehicle we are familiar with, question is, will we (or can Schummi) do any better by tacho watching? I think not.
Within design limits and street level margin of safety, the engine is in no greater danger of destroying itself at upper engine speeds. Surely you aren't going to label your mid range engine speed a self-destruction zone, referencing it to low engine speeds just a little over idling?What I meant when I said "leaving out the racing engines where power continues to rise well into the detonation zone" was power being produced well into revs where the mechanical limits have been exceeded and the engine is in danger of going kaboom, and was clearly not a reference to detonation in the combustion chamber at lower revs. I should have said "self-destruction zone".
I didn't say anything about pre-ignition except that it is not time dependent. I didn't even characterize detonation except explain one of its largest factors - time.But never mind, we got an interesting and detailed explanation on the difference between detonation and pre-ignition.
I should really be looking for higher torque over a high RPM range, rather than just higher peak torque?
titanic;169286 said:Am I correct to say that in order to get better 0-100km time, I should really be looking for higher torque over a high RPM range, rather than just higher peak torque? In addition 20" wheels should give me better 0-100km time than say 18" wheels (forget about weight first) because for the same RPM, I am covering more distance. Correct?
TripleM;169310 said:Conventionally speaking, larger wheel is faster but the smaller wheel allows quicker acceleration. This is because the smaller wheels hv less inertia to overcome and larger wheels have a higher road speed for the same rotational speed.
Shaun;169299 said:Like I said, there are almost no exceptions to the rule - especially in the context of the type of cars
and drivers in this forum, or any other decently built marque.
Shaun said:No driver-controlled shifting (street or race) in the world is to the nearest RPM. The human and the tach don't
Shaun said:You are setting your own unreasonable definition of data application and then calling it anal.
Shaun said:Using human feel you miss by far more than single digits, more like triple digit engine speeds at least.
Shaun said:You are making assumptions again.
Shaun said:It has been found that the human body is poor at sensing speed and acceleration (second derivative). It is
Shaun said:Within design limits and street level margin of safety, the engine is in no greater danger of destroying itself
goggomobil;169618 said:Exactly. It was the point I was trying to make. So when does Schummi decide when to shift? At the redline? or exactly at
the calculated optimum shift revs? or when he decides to based on his real world driving inputs?
I have described practical application. Many others apply it practically, using both visual and aural cues. In taller geared, large speed range cars, no aids are necessary because engine speed is rising slow enough to watch.No. It is application of data beyond what can be applied practically.
4. It is not practical for me to shift at exactly the calculated rpm, because I don't have time to watch the tacho, I can't read it to that resolution anyway, and there are other factors in real world driving.
5. so do I try to shift at redline? or calculated optimum rpm?
6. Working out that optimum shift was just some tens of rpm off redline (for example only) was a good exercise but I can't
apply it.
7. anal
Sounds like about as close as we can get by reading the tacho (bear in mind I have to do many other things while driving like keeping my eyes on the road), and we won't even get into the subject of tachometer accuracy under dynamic conditions let alone reading accuracy here.
What assumptions are you referring to, that humans should not be underestimated or that Schummi will find the best shift points (or close) without having to calculate it no problem?
Poor defined as bad, as inaccurate under common accelerations. I don't know the study. I know the concept has been confirmed by a range of sources, including a senior RH and NVH engineer for Ford who has worked for Lotus and Jaguar as well, a combat pilot and combat pilot trainer, the inventor and designer of a head restraint system set to rival HANS, my own race team's race engineer, driver development coach and race driver, and an R&D and technical director for F1 with over 20 years experience.How is "poor" defined, under what test conditions, and in which study has this been found? Just saying "People involved in production car ride and handling, or race driver development know this", is not sufficient to substantiate your sweeping statement.
No, when you drive you have visual input like scroll speed. There are also aural inputs but you are not actually sensing acceleration though feel. In the higher speed ranges and with a lack of markers or nearby objects for scroll, you rapidly lose all ability to sense speed and acceleration. Even at low speeds, the visual input is very poor resolution and does not correlate well to acceleration.Close your eyes you may not know your speed but acceleration...the human body can certainly sense... This ability to sense acceleration and its rate of change is exactly why we can feel of how our vehicle acceleration changes, and with experience is an important input
into deciding when to shift.
By the same argument, when we go around corners, do we sense lateral accelerations, listen to the sound of the tyres etc. (so we judge when we are losing grip) and drive accordingly or do we calculate it from the radius of the curve and coefficient of
friction between tyre and road etc. and drive to that? Sure we can work out the theoretical ultimate cornering speed under ideal conditions but do we then corner by watching the speedometer (since by your definition our butts are so poor at sensing speed and acceleration)? Surely not.
In my last post to you I did not refer to CC detonation in any way.Certainly not. Please read again, I was talking about race engines being capable of revving themselves to destruction (meaning excessively high revs beyond design limits, ok no rev limiter etc.). You are choosing to dwell on "detonation" in the combustion chamber.
SubZero;169543 said:Generally, a wheel with a 20" rim and one with a 18" rim should have the same rolling diameter if the proper inch up practice is followed. Therefore, both wheels would have the same road speed for the same rotational speed.
titanic;169777 said:Good point, the rolling diameter would be the same with proper inching up. But if the 20" wheel also have wider track width, would that give me better acceleration?
OK agree redline and optimum very close perhaps few hundred or even tens of rpm from redline, so shift at redlineShaun;169702 said:Race drivers, F1, sub F1, and above low level formulae, have progressive shift lights come on at
different rates depending on gear, which max out at the calculated optimum shift point (dependent on gear ratio), though this
is always redline talking strictly in terms of acceleration.
So actual shift points are very close to optimum, not many hundreds or thousands of RPM away from optimum.
Glad you brought up Visual and aural cues - both human senses, contribute towards "feel". Are you recognising the importanceShaun said:I have described practical application. Many others apply it practically, using both visual and aural cues.
Did I say take the tacho out of the car or avoid looking at it? Point (1) in my previous post; agree - shift at redline (useShaun said:4. You can read and react to your tacho in your street car better than a resolution of 250 RPM. You can miss a
shift point by 2000 RPM (factor of if you go by intuition and feel (which is not accurate)
Difference between optimum and redline small by your arguments, so shift at redline, especially on sporty or racing engine.Shaun said:5. Common sense dictates that it depends on he difference between optimum and redline (IF it isn't redline or
past redline). If optimum is 6489 and redline is 6500, then you can't make out that difference and it's up to you to try, but
even if you shift at redline you're off by 11 RPM, not much at all. If optimum is 6000 and redline is 6500, then obviously
you aim for optimum. If optimum is anything beyond redline, then you still shift at redline for longevity concerns.
tripleM said:I guess there's a myth out there that changing gears at redline get the best acceleration of the car.
agree again shift at redlineShaun said:It's not a myth, in fact it is almost a rule with modern petrol engines - especially so with sportier
engines.
No I did not, I have agreed with all your statements above - which is to shift at redline. I suggested that trying to shiftShaun said:You are the only one who has suggested mandatory shifting within tens of RPM of optimal, and then you have gone
ahead and labelled it anal. So this anal creation is all yours.
Did I say no time to glance at the tacho? I meant to sufficiently accurately read the tacho to get close to the optimumShaun said:If you have no time to glance at the tacho when conditions for performance driving exist, then I'm not sure
you're much of a driver.
2 separate points,Shaun said:Poor defined as bad, as inaccurate under common accelerations. I don't know the study. I know the concept has
been confirmed
experience. Never once have I heard that a race driver or other human can accurately determine acceleration, or best shift
points by feel.
Disagree, yaw acceleration at the limit can change quickly or not so quickly depending on the vehicle, tyres suspensionShaun said:Cornering is not the same as picking shift points because when you are cornering as quick as you can and reach
the limit, the
vehicle will let the driver know by yaw acceleration changing quickly and obviously (again, this is jerk).
Your primary school math syllabus is way ahead of mine.Shaun said:Also, the calculation for optimal corner speeds involves dynamics and calculation at the masters and doctorate
levels, since tire dynamics that are still not completely understood are involved, so the models are still somewhat
inaccurate. On the other hand, picking best shift points for best accel. involves only primary school math.
Now if we don't see peak torque RPM peak torque must occur aboveShaun said:It is very common not even to see peak torque RPM on an engine driven for performance - especially racing
engines.
Shaun said:You are confusing yourself because nearly all engines have power falling before redline, and it only continues
to fall past redline. If an engine has peak power at redline, then it has not been designed right. This applies to both
street and race engines. Power does not continue to rise well into the revs that are beyond design limit.
louis;170087 said:hmm, ok, may i ask, if torque is mathematically linked to HP, why do some engines have high peak torque and lower peak HP whereas others have high HP but low torque?
gasterus;170100 said:HP: how fast your engine can run
TQ: how strong your engine can run
